    Apr 2005
    LaLa land...
    Hi,
    While using GUI for dvdauthor to create a dvd, I encountered the following error log :
    "Can't find next AC3 frame: @ 99840 we have 0000 - broken bit-stream?"
    I used Rejig to demux to m2v & ac3.
    What am I doing wrong?
  2. Member Soopafresh's Avatar
    Jan 2004
    Trying your ac3 through Ac3fix
    Apr 2005
    LaLa land...
    hi Soopafresh,
    thanks for the quick reply... but another error :
    INFO: [???] AC3 AUDIO STREAM:
    INFO: [???] Bit rate : 49152 bytes/sec (384 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 8974696
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
    ++ WARN: [???] Discarding incomplete final frame AC3 stream 0!++ WARN: [???] Discarding incomplete final frame AC3 stream 0!
    **ERROR: [???] INTERNAL ERROR: droplast empty AU buffer
    ac3fix fixed the previous error but encountered this now...
    thanks
  4. Member Soopafresh's Avatar
    Jan 2004
    Dunno, bro. Looks like the AC3 is getting truncated. Might make sense to try another app to demux (DGindex ?), or for test purposes, mux with Rejig and see if it outputs correctly. Might also try running the original mpeg file through VideoRedo Quickstream Fix option in the program.
    Apr 2005
    LaLa land...
    thanks... any recommendation for "demux-er"...
  6. Member Soopafresh's Avatar
    Jan 2004
    Apr 2005
    LaLa land...
    problem solved using DGIndex to demux...
