Results 1 to 30 of 51
  1. If price were no consideration, which program would you recommend for a prosumer? Thanks
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    May 2003
    Peterborough, England
    If a trial is available, try both and see which you find easiest to use. Years ago I did this with Premiere and couldn't get my head round it, tried Ulead MediaStudio Pro and found it easier (for me). I've stuck with it ever since. Conversely, my father tried MSP and couldn't get to grips with it, he found Premiere easier and has stuck with that.
  4. I am by no means a professional, but I have been disappointed with the options available to me in simpler programs like pinnacle studio, so I'm looking for a program that will allow me to create prosumer level videos, doing a lot of editing and sound mixing, etc. I don't have enough time to be a pro, but would like to have those options there when I do edit video, as I am frustrated by simple programs that don't allow you much in the way of transitions, titles, etc.
  5. Member edDV's Avatar
    Mar 2004
    Either will work fine. Premiere is part of a large suite of programs. You may need to buy more. Vegas is more self contained for the "one man band" and has more audio features. IMO Vegas is also more stable in a home computer environment.
  6. Vegas is my choice. Everything else either doesn't do what I want, and/or crashes in the middle of a project.
    Vegas (5, and movie studio 4) are superbly stable.
    Haven't tried 6 yet.
    BTW, I found a site that has the Vegas 6 + DVD +AC3 plugin + about 4 other things, for $599
    Just goes to show, you don't have to purchase it from Sony.
    Cheers, Jim
    My DVDLab Guides
  7. Well seeing how I have Vegas 4, Vegas 5 and Vegas 6...Hmmm, lets see...Hmmm I vote for Vegas.
    Geronimo
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    vegas -- or vegas .. maybe vegas also
  9. Member edDV's Avatar
    Mar 2004
    Has anyone tried the layers import from Photoshop in Vegas 6? That was the main disadvantage vs. Premiere in the past.
  10. Originally Posted by edDV
    I have used it many times with Architect, There seems to be a bug with raster layers of some kind.I can upload the file if you want to try it and see if it will Crash. . Other then that it's GREAT. When you work on the Image in Photoshop or paintshop ,it update's on the fly.Very nice feature, reminds me of After Affects.
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If money (and space) were no object at all, then I'd have a Mac with Final Cut Pro just for editing. Meanwhile, back in the real world (at least, my real world), I have settled on Vegas for many of the same reasons others have. It has always been much more stable than Premiere for me. I'm sure Premiere is fine on a custom built machine that does nothing else, but my machine is multi-purpose. I like it's audio capabilities, especially mixing multi-channel audio for DVD. I like it's work flow, although in my ideal world someone would create a node based NLE.
    Mind you, if money were no object I'd use Digital Fusion instead of After Effects as well.
    Read my blog here.
  12. Video Restorer lordsmurf's Avatar
    To me, Vegas has always felt like the kiddie version of Premiere. I prefer the look and feel and layout of Premiere, and can really get work done when needed. Vegas just doesn't have that common-sense appeal. It may be because I have a long Photoshop/Premiere background, but nothing about Vegas entices me to switch "to the dark side".
    Final Cut Pro on Mac is also pretty good to work with.
    I think Vegas is better with effects filters, not so much the editing, but After Effects added to Premiere is a top notch package to go with. There's also a decent handful of Premiere plug-ins that do varying things, from restoration values (de-noise and de-shake filters) to creative/artistic things.
  13. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    I like Premiere. Never worked with Vegas, so I can't comment there.
    Despite what some say, Premiere is very stable for me. I've edited way more videos than I care to remember. I've been using Premiere since version 6, and the latest Pro versions are the best. There is nothing you can do in any other NLE that can't be done in Premiere, outside of true 3D rendering. Premiere is also very efficient, you can edit through your project at lightning fast speed with the latest versions.
    I'm sure Vegas is good, or no one would be using it. For me, Premiere is great and I have no interest in any others.
    May 2005
    brisbane
    Defiantely Vegas. I have used both. HATE Premiere....Vegas is the wet dream of editors.
  15. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Vegas is better hands down....Premiere alsways LOCK UP!!! I used over and over but went rendering it Locks Up.. Vegas doesn't Lock up its more stable..
  16. Most definetly Vegas. you'll get more editing done faster.
    May 2002
    Ontario, Canada
    THe first video editing program I used was EditDv 2.0. Excellent everything, easy, understandable, realy used friendly but...not for winxp, not for files bigger than 2GB (mere 9 minutes of film) not export to dvd, etc..
    Still looking for something similar. Got Premiere pro 1.0, only layout and look are similar, but way more complicated, no pan and zoom of still images, very limited title creation possibilities..also you have to have Encore to export timeline to dvd.
    good luck anyway!!
    Gregory001
  18. I run Win2k, so I only have one choice - Vegas.
    J
  19. Member lordhutt's Avatar
    Jun 2004
    Care to provide a link?
    You mention the AC3 plugin...will this allow me to edit my videos from my Sony DVD camcorder that outputs in mpeg format with AC3 audio?
    So far I have not been able to find any 'higher end' programs that support them.
    Thanks.
  20. Premiere gets my vote. I have the Adobe Video Collection Professional and I can create just about anything I want. In the 2 years I have used Premiere Pro , it has rarely locked up on me or crashed.
  21. Член BJ_M's Avatar
    Jul 2002
    Canada
    Thanks.
    vegas will not edit or import ac3
  22. Member edDV's Avatar
    Mar 2004
    Thanks.
    Vegas and Premiere are designed for original production. They both edit multichannel audio and directly support 5.1 editing including surround effects and spacial sound placement. They both place the AC-3 encoder in their respective DVD authoring programs (Architect and Encore).
    If you want to import from a 5.1 AC-3, you must externally demux the 6 audio tracks to base audio.
  23. Thanks for all the advice. It seems everyone is loyal to either vegas or premier. My plan, since I'm a student, was to get the educational version of Adobe Premier Standard (about $400). As stated earlier, if money weren't really an object, I too would have a mac with final cut pro. I guess I'll just have to wait until I'm rich to do that. Thanks for all your help. I have a trial of vegas so I'll give that a whirl and then decide. Any more input would be appreciated.
  24. Член BJ_M's Avatar
    Jul 2002
    Canada
    FCP is not gods gift to man -- talk about crashing all the time .. it would be a rare project where it doesnt crash ..
    and it really lacks a few features -- but does have some really good ones also ..
  25. Member
    SE_USA
    Yep, Vegas is the one.
  26. Member edDV's Avatar
    Mar 2004
    As I have said in previous posts, the choice often depends on your goals and the peer group you will be working with.
    It roughly breaks down this way for the big four.
    AVID -
    Professional film and episodic TV production.
    Cable and local TV feature editing (inhouse)
    Ad Agency (inhouse)
    TV station news editing
    Adobe Premiere -
    Corporate multimedia departments
    Graphics and print oriented production facilities (multi-use media)
    Academic, engineering and scientific use
    Niche market independents.
    Home video editing - small share
    Apple FinalCut Pro
    Post houses - Light duty edit and prep bays using freelance editors
    Ad Agency - second to AVID but growing
    Independents (local ads, wedding video, business media) - second to Vegas
    Sony Vegas*
    Independents (local ads, wedding video, business media) - very strong market share and growing
    Home video editing - highest prosumer share
    * Vegas is the new upstart recently acquired by Sony. Sony's goal is to dominate independent and prosumer market share in support of its HDV launch. A longer term goal is to get Vegas established in professional SDI production environments and TV stations in direct competition with Final Cut Pro.
  27. Член BJ_M's Avatar
    Jul 2002
    Canada
    Though to be clear - AVID for film production is a 50-100,000$ system .... but it is a standard....
    Several films have also been CUT on both FCP and Vegas also.. Lots of Music Videos and Consumer DVDs (lot of training dvds have been done on vegas) have also been on done on both systems ..
    Ad Agency - yea , FCP is very popular due to the large amount of apple systems in this classification ..
  28. Member edDV's Avatar
    Mar 2004
    Far more than that just to get started.
    Offline cut yes but they never tell you about the team of 10 and the post house that finished the big scale project.
    Ad agencies and post houses desire standardized work environments that have ready freelance operator communities so that they can hire qualified people on a project basis and not have to train them. Both AVID and Apple have invested heavily in development of a freelance operator base. Sony is just getting started with this. Up until now, the Vegas user community has been self taught and generally work for themselves on projects that they will finish.
  29. I use Premiere so cannot comment on Vegas. One question though...
    Can you use encoders that plug into Premiere in Vegas? like Procoder and/or Discreet Cleaner. If so I wouldn't mind getting a trial of it and trying it.
    thanks.
  30. Член BJ_M's Avatar
    Jul 2002
    Canada
    Premiere can frame serve to any encoder....
