Would there be any real reason to install Adobe Premiere 5.1 if you already have Vegas Pro 8? Anything it does that VP8 doesn't or anything it does better than VP8?
Biggest reason would be Mercury Playback Engine - If you have a compatible CUDA GFX card, some effects , filters and manipulations like scaling are GPU accelerated. Rendering can be a lot faster, sometimes 1-20x faster depending on the project . But you should go to CS5.5 update if you were updating, not 5.1 (some important fixes)
A negative is that it is waaay more bloated compared to Vegas Pro 8. Even newer Vegas versions are way more bloated. They require signifcantly more CPU, RAM, HDD space just to run the damn thing
So if Vegas Pro 8 does everything that you need to , don't install Premiere -
Vegas Pro 8 is getting a bit long in the tooth (old) as the current version is 11. Recent versions deal with AVCHD format better if that is a consideration.
The other advantage for Premiere is tighter integration with AE, Photoshop and other Adobe apps if that is a consideration.
Learning Premiere from scratch is a significant adjustment.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Are you talking about Adobe Premiere 5.1 or Adobe Premiere Pro CS5? These versions are at least 10 years apart.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Footage captured in Sony Vegas compatible with Adobe Premiere Pro?
By snoutproductions in forum Software PlayingReplies: 15Last Post: 21st Jan 2012, 10:28 -
Vegas Movie Studio Platinum Pro Pack vs Adobe Premiere Elements 8
By bowmah in forum EditingReplies: 6Last Post: 27th Jan 2010, 20:15 -
Vegas Pro 9 versus Adobe Premiere CS4 ?
By Chrushev in forum EditingReplies: 1Last Post: 23rd Oct 2009, 18:23 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
Vegas Pro 8 versus Adobe Premiere CS3
By SCDVD in forum EditingReplies: 9Last Post: 26th Feb 2008, 17:57
