see threads >
https://www.videohelp.com/forum/viewtopic.php?t=258749&highlight=
https://www.videohelp.com/forum/viewtopic.php?t=261524&highlight=
Well it was the Fan/ Heatsink on the CPU causing all my problems and causing the program to crash when CPU temp went up...
I removed heatsink and fan , gave them a really good clean ( couldnt belived how much dust was clogged up in the heatsink fins) , then i cleaned off the heatsink and cpu face and applied Artic Silver Thermal Paste.
B4 my cpu temp went from 40 oc on start to 83+ oc when running SVCD2DVD , now it goes from 40 and stays at a constant 50 oc.
I have completed my 1st avi to dvd with this program ..
Thanks for any advise i was given and i hope my problems may help someone else if they are getting crashes.
all4free:
Glad to hear you got it fixed. Dust is a big problem, I use canned compressed air fairly regularly to keep my fan intake/exhaust ports clean as well as blowing ot all the heatsinks and fans. If I let it go too long I have seen as much as 12 degrees difference on the CPU.
Happy converting.
Trojan Virus=C:\FOUND.011\file0000.chk. - Problem Solved
By blinky88 in forum ComputerReplies: 10Last Post: 6th Feb 2013, 23:17 -
I think I have found the best spray!!
By RickTheRed in forum MediaReplies: 113Last Post: 22nd Aug 2011, 01:54 -
FOUND files ??? need a little help, please
By blinky88 in forum ComputerReplies: 6Last Post: 22nd Jul 2011, 13:50 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 12:23 -
Found pulldownbatchFE
By Krelmaneck in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 15:17
