  1. Hi everyone hows it all going? I have a little issue with AutoGK when I try to convert a .ts file to .avi when I click start, it pops a Error box up saying 'No video sequence header found' then if I click ok on that another error box pops up saying 'No data. Check your PIDS.' Does anyone know how to fix this the .ts file is 2.2GB from HD source. (If that information helps?)
  2. ts is a transport stream .. In uk normally a freeview stream directly recorded via HAUPPAGe software .. You need something to convert this to mpg, which autoGK will handle with, aplomb. I know Video-redo will do this, other software too. Its a 10min process, just "reorders" the file on disk.
    EDit .. ahhh HD source is different... possibly mpeg4 ?? mediainfo
    The electronic components of the power part adopted a lot of Rubycons.
  3. Thank you very much for the information have been stuck on this for a couple of days now.
