Hey y'all!
I am presumably gonna get framed and yelled at after posting this thread. You will all tell me to read others threads or basiclly go f*** myself.
But I seriously need some help. I have searched for my answer in this forum, but havent find anything. Well nothing that I understand with my shitty english. Thats why you guys are my last hope![]()
Well my problem is not a big one, just the solution is maybe. I have a korean movie that only has DTS audio. And my standalone DVD player doesnt support that. And sry to say that I dont have money to buy a new reciever etc etc.![]()
Is there a way to take the DTS audio, and convert it to DD ?? (my dvd player supports Dolby Digital, thats what the info says "Dolby Digital 5.1)
Then after the convert burn in to a DVD-R togehter with the videofiles?
Please if you are a kind person, plz write some nice answers. Which appz should I use etc etc, or maybe post a link to guides/articles.
Or if the answer is found somewhere in this forum, plz post a link. Most of the threads Ive found were hard for me to understand.
Thanks very much for reading this
Bye bye
Results 1 to 23 of 23
Hello,
Check out besweet.
It can convert almost any audio format to anything else. You may need to purchase the dts plug in. Not sure as I don't do much with dts - I usually leave that alone.
Good luck.
https://www.videohelp.com/tools?tool=Hypercube_Transcoder
or besweet with a plug in ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I know 4 diffrent methods:
two methods uses filters from WinDVD (5.x +)
-> Hypercube Transcoder + further DS Filter
-> Azidts (+ besweetGUI)+ further DS-Filter
dtsdec 0.02 (download
-> commandline tool (donīt forget the '>'
foobar2000
-> decodes DTS via diskwriter utliliy
itīs on you which one do you prefer
you always end up with 6 single mono WAVs
finally you have to feed those WAVs with your favorit AC3 encoder and mux the AC3 with your MV2 to your new DVDVideo
bye Daphy
PS: whatīs your native language? maybe I could help you
Answer on personal message:
first you have to demux the streams inside your VOBs - there are many solutions to do this:
f.e. vobedit you will find this @ the demux functions (-> itīs better to save the vob/ifo files on hd before start any other action!)
next: audio decoding
now you have dts file! next is download the latest foobar2000 - special version
open the dts file by dragīnīdrop into the playing list. Then use right click on the file 'convert' > 'Run conversion, single file output' use 'WAV PCM fixed point' and save the file.
next: audio encoding
download f.e. HeadAC3 (latest version) (mirror) and give your WAV as input, chose AC3 as output finally you ended up with a new AC3
next step remux your AC3 back to your VOB project, how? use IFOEdit and author the DVD new or ask other VIDEO-Cracks on this board!
If youīve found a method to do this, please post it here to give the board a complete 'guide'
[/url]
hey daphy!
I have encountered another problem. When I tst to convert the dts file in foobar 2000 I get this message in the consolewindow:
"INFO (CORE) : startup time: 1766 ms
ERROR (foo_diskwriter) : Conversion failed."
Is there a codec I need before converting the dts file in foobar? -
1. can you replay the DTS? fix the file with beslice/besplit
2. did you really download the 'special' version of foobar2000? -
I tried to read the thread link you posted daphy. And followed to guide there, but I still dont get it. It says you should search for "FAAC : MP4(LC),quality 100" in the list (preferences --> diskwriter). But in my scroll list I only have two kinds. WAV(fixed point) and WAV(floating-point).
Why is it so hard to just convert a file!!!
All the guides seems incomplete, because always when I try them I always get stuck. And the playback in foobar2000 didnt work. Got this message:
INFO (CORE) : startup time: 94 ms
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "file://D:\VIDEO_TS\dts_to_ac3\VOB1\VTS_01_1.8a.dts" (0)
ERROR (CORE) : error opening file for playback :
never had a problem with it
please answer those two question befor we go any further - btw it must be WAV fixed point!1. can you replay the DTS? fix the file with beslice/besplit
i also remember now -- procoder 2 has a dts decoder/transcoder in it ..
it will read any dts file and can convert to wav any audio format BUT ac3 .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yeah, this one is really cheapProCoder 2.0
Catalog No > 706222
MSRP > $499.00
hi daphy!
I have tried fixing one of the dts file with Besliced. And I got a big logfile with errors. Thats kind of wierd, because I extracted the dts file like your guide said. Anyway after the fix I opened the fixed file, which was 284MB. The first file was 750MB.
Trying to playback the fixed file in foobar2000 special version gave me the same error like before.
INFO (CORE) : startup time: 1156 ms
INFO (CORE) : location: "file://D:\VOB1\VTS_01_1.8a_Fixed01.dts" (0)
Would you recommend the BeSweet convert option?
Or should I use your guide. I think your guide is great, but I keep getting errors and cant continue
Hit me back! -
Ok guys, thnx for all you effort trying to help me. But I cant do this, I dont understand the appz. And I think you guys dont wanna write a whole guide just for me.
So Im gonna try using Besweet with DTS plugin. Where can I find this DTS plugin?
I have downloaded the latest besweet from doom9. But I dont understand it all.
BJ or daphy, if you got the time. Plz write me a little guide. I really want to watch this movie. But it only has DTS audio
First you have to install windvd 5+ (no demo - the fullversion! because this software includes the needed DS Filter for decoding)
-> besweet: please use the installer version from my home page http://www.needfulthings.webhop.org/ it includes the rest!
then use your DTS file as input output 6 single WAVs (AC3 might not work direct -plz try it out) if it wont work do it in two steps.
-> the channel mapping between DTS and AC3 might be diffrent (DTS: L,R,C,LFE,SL,SR - AC3: F,C,R,SL,SR,LFE) keep this in mind when you mux the single channels back in a 6channel-WAV (also known as 6WAV) for encoding f.e. by HeadAC3 or besweet itself.
how to mux? take a look at 31. -
guide here (go down to method #2)
http://www.app.demon.nl/DTSguide.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
How to convert AC3 to DTS
By lhockann in forum AudioReplies: 8Last Post: 3rd Jan 2012, 08:31 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 09:23 -
Convert DTS 23.97 to 25 ??
By Summersun78 in forum AudioReplies: 1Last Post: 14th Nov 2009, 04:15
