Not sure if this is in the right section.
After I ripped a BluRay with DTS-MA, I'm using Xmedia to encode to mkv. I'd like to convert the DTS-MA track to core DTS but I dont see the option. Is there a way to do this? If not, is there another program (freeware) that will? Is there a huge file size difference between DTS-MA and plain DTS? If not then I'll just leave the DTS-MA intact. Thanks.
Thanks.. but what about the filesizes? Is there a significant difference between master audio and core?
eac3to
Well, "huge" is a point of view.Is there a huge file size difference between DTS-MA and plain DTS?
Anyway, the "normal" Master Audio format cannot be efficient, compression-wise, exactly because it "depends" on the lossy DCA core
. OTOH, and BTW, there exists a "coreless" version of the Master Audio format, BUT it's not / cannot be used for Blu-Ray authoring ( also, I haven't seen/heard any samples of the "exotic beast" so far
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert miniDV to h.264 using XMedia Recode. Fast moves are very ugly...
By marqus in forum Video ConversionReplies: 3Last Post: 15th May 2011, 04:53 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
