Hi.
I have one mkv files that has dts-es(Or any other extra dts)6.1 or 7.1 channels and i want to make it into dts-core 5.1 channels
How i can do that?
I try to use programs like tsmuxer or mkvmerge but nothing happened.
The mkvmerge 4.8.0 it bring me some errors like these:
Resyncing successful at position 9015452201.
Lord of the rings\The fellowship of the ring extended edition.mkv: Error in the Matroska file structure at position 9081333132. Resyncing to the next level 1 element.
Resyncing successful at position 9081502749.
Lord of the rings\The fellowship of the ring extended edition.mkv: Error in the Matroska file structure at position 9098077418. Resyncing to the next level 1 element.
So what i can do to correct that mistake?
A lot of thanks for your time.
try multiavchd it may allow you to change what you need to.
I want a program that it is easy and DON'T change the resolution of the movie at all ONLY THE AUDIO DTS-ES nothing else.
This multiavchd do that? -
I'm not sure about the audio settings in multiavchd. I'm pretty sure it does.
However i know for sure you can use eac3to to do exactly what you want to do. It will make a regular 5.1 dts from a hd dts file.
But please note a 6.1 dts es can be standard definition audio and work just fine on any system. I believe lord of the rings extended edition dvds were 6.1 dts es and work just fine on plain 5.1 dts systems.
Its the hd master dts ma audio you are probably wanting to convert. Just though I'd mention the differences.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
convert DTS from MKV to AC3
By cajmere in forum AudioReplies: 19Last Post: 9th Nov 2011, 21:04 -
Convert MKV + DTS to work with PS3
By robert7lee in forum Video ConversionReplies: 17Last Post: 27th Jun 2011, 17:36 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50
