Results 1 to 30 of 37
  1. Well, I got my Teac burner setup as a dual layer capable dual format drive and the first thing I did with it was copy a DVD to DVD+R. I used DVD Decryptor and copied LOTR: ROTK WS to my HDD. I then used Nero Recode to "Remake A DVD" and got rid of everything but the main title and the 2 channel english soundtrack. The video quality got to 60.8% and I used "Advanced Analysis" for better quality. I can hardly believe how good the copy looks and sounds. In fact, I can't really tell a difference in the picture between it and the original. Is this what I should expect from using this process? Is everyone getting these type of results? Lastly, is there anything I can do to improve the end product?
    Thanks.
  2. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Did I miss something here, you burned a dual layer and got it recoded to 60%? If it is 1 dual layer disk copied and burned to one dual layer disk, how could it be reduced to 60%?
  3. Shrink can produce excellent results even with this level of squeeze. I've run double Shrinks on videos before and still had good results, so a 60% result certainly can be as good as your eyes are telling you...
  4. What is the model # of your TEAC burner? DV-58E?
  5. I never said I burned a Dual Layer DVD, only that I got the drive setup with that capability. Sorry if that wasn't clear.
    Yes, I am quite pleased with the results. But, now that DL is a real option, even this method will soon besome obsolete. That is, once DL media becomes affordable.
    The Teac model number is DV-W58G-A02. It is a Lite-On SOHW-832S for half the price now.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Seems to me like Sulaco has just discovered what many of us have known for months, maybe even years. This will be one of those NOOB posts you will look back on in a few months and think "Why the hell did I post that?"
    If in doubt, Google it.
  7. Member Treebeard's Avatar
    Aug 2002
    Afforadability is not the only issue with DL. Compatability w/ existing players sucks and I think DL burning is still a ways away for consumers. Who is going to want to buy new players to play these DL? Ill stick w/ my single layer dvd burning for a while.
  8. Seems to me like Sulaco has just discovered what many of us have known for months, maybe even years. This will be one of those NOOB posts you will look back on in a few months and think "Why the hell did I post that?"
    What is that supposed to mean? I don't know how to make what I said any more clear. And I am not a "noob". In point of fact, I have been here longer than you.
  9. Member GKar's Avatar
    Jul 2003
    My mistake, your original post did say DVD to DVD+R backup.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What that means is that many many people have known about programs such as Nero Recode, DVDShrink and DVD2One as well as a myriad of other programs that can transcode/re-encode DVDs to fit on a DVD-5.
    Given that you have written:
    ...and the thread title is: IT WORKED!! Now a question?
    So, the first thing you did was copy LOTR. You didn't know what to expect, you don't know if an almost identical copy can be improved upon, and you were surprised/overjoyed that it worked...
    To me that implies it was your first attempt at burning DVDs. If I was wrong, I apologize.
    Does that mean you joined here the day you started burning DVDs/VCDS/SVCDs ?
    I know I didn't. My first CD burner was purchased in 1997.
  11. I am not going to argue with you LOL!
    And stop hijacking my thread.
    Thus far you have added absolutely nothing of any benefit to me.
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I've increased my post count by 3.
    Because you're being such a wanker about it, I will answer your questions:
    Yes. That is why these programs are made. What do you think you should expect ?
    Yes. I sort-of alluded to this when I said that a lot of people have known about this for quite a while. A forum search would have given you the same answer.
    Different transcoders can do varying jobs of the same movie. All that matters is that you are happy with the quality.
  13. Banned
    May 2003
    Massachusetts
    Sadly, the more time you spend looking at reduced DVD's and originals and making comparisons, the less happy you will be with transcoded output. It's like a learning process...
    Phase 1:
    Single layer backups.
    Phase 2:
    One-click transcoding.
    Phase 3:
    "Advanced" transcoding.
    Phase 4:
    Movie-only re-encoding.
    Phase 5:
    "Advanced" re-encoding.
    Of course, new programs like DVD Rebuilder are making Phase 4 obsolete, and you skipped phase 2 entirely.
    - Gurm
  14. What firmware did you flash the drive with that added the capability?
  15. I used a firmware from this site.
    http://codeguys.rpc1.org/oc.html
    The Teac DV-W58G-A02 is a re-branded Lite-On LDW-812s (or something like that, not looking it up right now) and the 812 is actually an 832s which is the new Lite-On DL drive. [/url]
  16. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I know this is off topic but the best thing about posts like this it to read them and just think 'I was new to this one time and got a hard on with my first successful backup' and walk away instead of adding childish posts and name calling but you alway get one
    who gives a flying flock if Sulaco reinvented the wheel and why does it bother people so much if he tells others?
    Gurm has got it spot on as most people will be happy with results probably because they haven't experienced the other options or do not have the means to see a 'true' comparison. Basically Sulaco is chuffed with the quality so chill and walk away unless you can tell him in a nice manner that this is just the tip of the iceberg and there are other tools that will give him better quality if he wants to put a little research into it
    all he needs is a simple push in the right direction
    how long you have been a member and post counts mean sweet FA and shouldn't even be mentioned :P
    p.s. the posts are harmless really but I guess the 'wanker' name calling part is what got my attention. Imagine sitting in a pub and chatting to someone you don't know. After 2 exchanges of conversation you then get called a wanker. That person would be sat on their arse before they had even finished the sentence. Some attitudes in forums would get people a good kicking in my neighbourhood but I suppose it's too easy to hide behind a monitor
    call me the forum police or whatever you want but jimmalenko it's time to grow up mate
  17. Thanks MackemX.
  18. At 60% it may look fine on your tv, but wait until you try it on a high def set.
  19. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    no thanks necessary mate
    just making a point that's all as I hate people who get abusive to those less knowledgable or less inexperienced and that name calling was a little OTT for me I suppose
    anyway, I know you are happy with 60% but what setup are you using to view the backup? How big is your TV etc?
    bottom line is that a few of us here know that if we were in the same room and pointed out the differences in your backup, you would soon be looking for something better . I've done this quite a few times with friends and family . Basically it just depends on your perception of quality and the equipment used to view the video as to whether you are satisfied or not
  20. I have a Sony TV. It is a 36" Trinitron and on this particular DVD, I used the "16:9 Enhanced Mode" for playback which basically compresses the horizontal scan lines to give a more "Progressive" appearance. All I have to do is set my DVD player to output to a 16:9 TV. (To me, it looks as good as a true Progressive Scan image when using a reference DVD.)
    I use a good quality component video cable from my source which is a Sony DVP-N655P DVD player.
    I looked at the DVD again and I really am amazed at how well it turned out. I have created plenty of stuff on CD (SVCD, etc.) and have also thrown some things on DVD,< but this is the first time I have seen an image this comparable to true DVD quality.
    Maybe I can take a picture of it tonight so you guys can see for yourselves and maybe give me some input.
    Oh, I also played it on a Toshiba DVD player using a junky composite input to a low-end 27" TV and it still looked good.
    I dunno, maybe my inexperience with video editing is what makes the picture quality seem so good but I am not new to video, only to video editing, so I like to think I know a good picture when I see one.
  21. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Honestly, why should anyone care about any post? Because discourse is the backbone of any forum, that's why
    What I got from jimmalenko's post (correct me if I'm wrong) was a very mild ribbing to someone who all but stated that they are a n00b. Kind of like someone's first beer getting them wasted and someone saying, "next year, you'll probably need a six-pak to get a buzz." (using the pub analogy)
    As far as the name calling, Sulaco is the one saying his dick is bigger, so it's obvious he's not being jovial about it. 20 posts in 2 years is not very contributory to this community, so "I've been here longer" means nothing.
  22. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    no real need for picture comparisions as some parts of the DVD will probably look identical to the naked eye under normal viewing conditions. The parts that may show a slight difference are fast moving multi coloured scenes
    there will be differences in some areas that could be pointed out but it's not as obvious in this case as I would presume that LOTR is 2.35:1 which will contain black bars in the image. This will have an effect on the quality as space can be saved just on these black bars alone
    some other factors that will affect end quality are the original average bitrate and quality of the transfer
    if you used 60% on a 4:3 DVD with a low bitrate, poor source and fast action scenes then you may see a totally different picture . This is why you get such a varied opinion of acceptable quality settings from people
    one of the tools that uses CCE probably be of more use at 60%
  23. one of the tools that uses CCE probably be of more use at 60%
    What is CCE and what tools do you mean?
    I see what you mean about the source difference. I will have to try a poorer quality DVD and see what happens.
  24. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    lol , I'm not surprised by your attitude one little bit Supreme2k
    I mentioned it was actually harmless but it's the actual 'wanker' part that I stated in my p.s that got me to post. I suppose that's another attitude problem I also notice around some forums, if you are not loyal to a forum then you are not welcome
    yet again who gives a flying flock if someone joined when this site first started but only now decided to post? Replies like that will just force them to go somewhere else
    I can argue all day with you and get you to snap and start with the name calling (I could name a few members straight off) all day mate but bottom line is some people don't wanna see the shite that some ego boosting arseholes post around here and I guess 95% of others don't either. This is a DVD forum with people of various abilities not a f'in junior school playground
    let's just see how many more worms come out of the woodwork now I've said something . The wiser ones will actually say nothing at all and let this thread get back on topic or die a fast death 8)
    if the guys I sometimes jump onto don't like the heat then stay outta the kitchen
  25. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    CCE is Cinema Craft Encoder and is an encoder that other programs can use to re-encode the video. DVD2DVDR is a program that uses CCE as the encoder and does most of the setting up of CCE for you. DVDRebuilder is another one but that also does complete 1:1 backups. It may be a little confusing at first but once you do it a few times it's rather easy
    try a search and you may find more info about it as to what it does and people's opinions
  26. Greetings Supreme2k's Avatar
    Feb 2003
    I guss it's just best to avoid your posts, since they are nothing but inflammatory.
    It matters a great deal that someone posts so little, then starts a thread like this one. It shows that they haven't even been reading posts that show that this subject/method is old hat.
  27. Oh ok, I wasn't sure about the abbreviation.
  28. Member GKar's Avatar
    Jul 2003
    Phase 1:
    Phase 2:
    Phase 3:
    Phase 4:
    Phase 5:
    - Gurm
    Gurm or MackemX, I downloaded all the stuff for DVDRebuilder, just curious as to how long it takes to process with QuEnc in the high quality mode on an average 2 hour movie? Rough estimate?
  29. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    bully for you, MackemX. If you don't like it you know where you can stick it. Go back to post-whoring DVDRemake.
    My posts are my opinion, to which I am entitled. As Supreme2k pointed out, the "wanker" call was mildly tongue-in-cheek.
    I believe Sulaco has the wrong attitude and I have attempted along with many others to point out that this really isn't rocket science.
  30. Banned
    May 2003
    Massachusetts
    GKar,
    No idea. With CCE in 2-pass VBR mode, on my machine, the entire process start->finish takes somewhat less than 3 hours. I'd say closer to two, but I haven't timed it.
    - Gurm
