I was using BD rebuilder 3.101 and it worked. Now it gives a 'beta has expired, please get newer version'. Ok, so I got 3.105, gives "Error in attempt to extract audio subs. Failed to extract audio." And so I removed 3.105 to go back to 3.101 and I can't. Arrgghh. Tried it more than 3 times, rebuilding that is. Any help here? Nothing, nothing has changed except for that. All was working. Doh!
thanks!
Results 1 to 10 of 10
I want my stuff, not your stuff. Ok, we can share.
Pull! Bang! Darn!
Originally Posted by TomBud
It turned out that the drive I was using to write the rebuild to didn't have enough available free space for BD Rebuilder to work with.
So I deleted/moved some files to make more space and it then worked.
So I would check that you have enough free space first, I don't know for certain how much free space is required but I would recommend you have at least as much free space as the size of the original Bluray movie. -
Thanks both. I removed and reinstalled latest versions of all sfwre and it works! I also did clean up the drive because it only had 28gb left after encoding started, so in either case it's encoding. However - sorry, you knew there'd be one - It is taking excruciatingly long time; like more than 14 hours. It's never taken more than 4-5. What's up with that? I put bdrebuilder 3.104 because author says .05 is very beta and according to the comments it is. HNY!
I want my stuff, not your stuff. Ok, we can share. -
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Started at 10 last night, it's 1:30. But it will be done soon! Wow, hope next one I try isn't this long. Almost makes backing up and putting on a server worthless. My sys is dual-core 2.5ghz w/2gb of ram, but ffdshow is consuming both cpu's at 100%! Only 800mb of ram is being used. I did check- settings are high quality (default) and options BD-5. Screen cap included.
Thx all.
Task Manager show's cpu running permanently at 100%
I desperately need to upgrade to something Dual/Quad core.
I reckon it would be cheaper for me to just buy 2 copies of the movie rather than backing up to BD5/BD9 -
Originally Posted by HARRYSPADGE
BD-RB is gonna' have your cpu cores @ 100% unless you have a newer dual quad Xeon or Opteron system, and still "may peg the cores" even on them if it has a fast RAID array
ps. my Regor core Athlon II X2 245 ($66USD) PC does BD reencodes in a more reasonable 12-14hrs, a oc $99USD Propus shoudn't take more than 7-8hrs as my Deneb core Phenom II 940 BE (same thing but w/ 6mb L3 cache) reencodes BD's in about 5-6 hrs, some under 4hrs
ocgw
Originally Posted by TomBudPull! Bang! Darn!
Originally Posted by fritzi93
BD Rebuilder show that the beta is the expired date when the first run.
By wisitch in forum Authoring (Blu-ray)Replies: 2Last Post: 12th May 2011, 08:29 -
I was surprised an ip masker really really worked
By yoda313 in forum Off topicReplies: 0Last Post: 22nd Feb 2011, 14:49 -
I have tried many media converters for HD, none of them worked
By calande in forum Video ConversionReplies: 2Last Post: 11th Jul 2010, 20:02 -
.MKV to DIVX worked but not really
By cabala in forum Video ConversionReplies: 7Last Post: 7th Oct 2007, 18:58 -
Mkv extract... worked once.. now flawed!
By Mushmello in forum Video ConversionReplies: 2Last Post: 1st Jun 2007, 11:22
