Results 1 to 13 of 13
  1. WHEN BACKING UP MY PURCHASED DVDS ON MY 106 THE DISCS ALLWAYS POP OUT AT THE END AS THEY SHOULD, RIGHT.BUT ON THE MOST RANDOM OCCASIONS THEY HANG AND STAY IN,THE ONLY WAY TO GET THEM OUT BEING TO REBOOT.THE DISC IS ALLWAYS OK.I KNOW IT ISN'T THE END OF THE WORLD BUT IT ANNOYS ME.ANY1 HAVE ANY IDEAS WHY THIS HAPPENS?
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    It might be bad media. Please don't type in caps.
    Apr 2004
    The bottom of the planet
    7/16s of one inch.
    That's all the distance you have to move your smallest finger in order to not look like an obnoxious idiot.
    You're also likely to get more helpful answers if you describe the entire procedure you're using. What software you're using to burn the disc is always a good start.
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I REALLY HATE IT WHEN PEOPLE TYPE IN ALL CAPS IT TENDS TO IMPLY THAT THEY ARE EITHER VERY YOUNG CHILDREN OR COMPLETELY IDIOTIC ADULTS OR SIMPLY CRAZY BEYOND ALL HOPE.
    IT'S A SMALL THING BUT STILL PEOPLE WHO TYPE IN ALL CAPS ARE ANNOYING AS ALL HELL.
    - JOHN "FULCILIVES" COLEMAN
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
  5. listen guys why cant anyone on here just answer the question .everyones a smartass.u call me obnoxious.i dont need to explain the entire process cos i know what i'm doing and besides 9/10 times its ok.how on gods green earth does me typing in caps translate to me being obnoxious.f**k me gently.why dont you guys go and watch hackers for the 48th time and give yourself piece.there you go all in small case.guess i'm in the cool club now.
    dvd decypter
    dvd shrink
    ritek GO4 (oops) caps sorry
    Apr 2004
    Asked, and answered. Let me refresh your memory:
    Now that you have provided something of an answer, I can honestly say the problem is not with the software you are using. DVDShrink and DVDDecrypter, in spite of being freeware, are two of the most reliable pieces of software you can get for these procedures. I am unfamiliar with the media, but if you look at the DVD Media button on the bar to the left of these forums, you can search for a manufacturer ID and get the lowdown on how reliable people think these discs are.
    Finally, you would do well to remember that noone here is obligated to answer your question. We do not get paid to be here, so if you present your question obnoxiously with no helpful information, it is very likely that people will respond in kind. Without knowing what options you have turned on during either stage of the process, it is hardly likely that people can be expected to be too helpful.[/quote]
  7. I think this might happen when you have a lot of left over room on the disk. The burn finishes and the program indicates that it is done but it is still doing something with the rest of the space on the disk.
    This is just a theory in progress. Might be a dumb one.
    (Out of curiosity, why DID you type in all caps in your first post? One of the very first rules you learn in forums is that all caps is shouting. I'm not looking to flame you over that again I just wonder if some people just use all caps for their every day work and then when they post to a forum it is just on, OR are they using all caps because they think it gets more attention, or something else. )
    Aug 2002
    cleveland, oh
    spiritwalker,
    There are many of us who are willing to help you, but SHOUTING at us is NOT the way to get the help you want. What you'll get is flamed to a crisp.
    Seeing how you have chosen not to give the necessary information in your profile you must think we are mindreaders. Therefore I guess that you have a 486 computer with 48K of RAM and 5 meg HD, with Windows 3.1. Please correct me if I am wrong.
    The most likely reason for your drive not to open is that the DVD has failed to finalize. More then likely the cause is bad media. Once again it would be nice to know what type you are using. I would guess that it's the cheapest stuff you could buy.
    The next time this happens try looking at the processes in Task Manager and see if you are hung up in some process. You shouldn't just reboot the computer to clear this problem, you lose any system information to help troubleshoot the problem. Instead insert (carefully) an unbent paper clip in the little hole in the front of the drive, push until the door is released.
    Your app should terminate with some type of drive error. Now apply standard Windows troubleshooting steps to find out why the process hung up. (try checking the Dr. Watson file).
  9. Originally Posted by spiritwalker
    dvd decypter
    dvd shrink
    THE PROBLEM IS BTCATK - BETWEEN THE CHAIR AND THE KEYBOARD
    It's time to kick some butts, and presto ( if you know what I mean )
  10. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Hackers, what a cool movie. I think I will watch it when I get home, thanks for the idea.
    Apr 2004
    Isn't it amazing how the tech-illiterate try to pretend they have a superiority when it is pointed out to them that their computer and communication skills suck?
  12. Video Restorer lordsmurf's Avatar
    dvd decypter
    dvd shrink
    Knowing 9/10ths is great, but almost isn't going to be good enough, is it? For that 1/10th you don't know, have some manners and respect when asking for help.
    Anyway...
    One of my drives does this on Win XP. Win XP caused it. The disc is fine. Just end tasks, or simply reboot. Always comes out fine in the end. I have a ROM that locks down too. Easly Pioneer 103 had safety lockdowns for odd errors, needed reboot.
  13. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    CAP or uncap all you like
    your still an obnoxious idiot, and deep down you know it
