    Jan 2010
    Hey there -
    There's some video collections on You Tube, good quality and in 9:59 segments I am trying to burn to DVD with no luck.
    I've used Nero, DVD Flick, NTI - WinAVI and Ipod video converter - they all start hanging up twenty minutes or so into playing no matter how I configure the burn. Segments - merge into one.
    I'm using Maxell DVD-Rs so maybe that's the problem - any advice?
    Apr 2004
    Miskatonic U
    ConvertXtoDVD can merge parts into a whole, as can AVStoDVD. Both are worth a try.
    Read my blog here.
    Jan 2007
    Republic of Texas
    Try Verbatim discs. Maxell ain't the most reliable.
    Jan 2010
    Well I was wondering if it was the discs or the methods of converting and burning.
    I'll try another brand but the site said these Maxells were pretty reliable.
