How do I compress GIF, as well as APNG and animated WEBP files without losing any quality?
Results 1 to 29 of 29
Try 7z https://7-zip.org/ .
And btw i do not expect high compression gain but for sure eventual compression will be lossless.
Seem http://mattmahoney.net/dc/zpaq.html offers highest lossless compression so i would try ZPAQ firstly.Last edited by pandy; 30th Mar 2024 at 11:19.
Except of course, GIF has limited color palette, so if source is standard 24bit color (or anything higher than 256), there WILL be loss.
Scott -
Image compression using one of the PAQ series of file compressors.
Advantage of PAQ compressors is high lossless compression of files. Disadvantage is compression may take a long time, depending on compression options.
Natively the PAQ compressors are run under command line, so may be difficult to use/understand at first.
However, there is a GUI available for the PAQ compressors here which may make it a bit easier to use. -
Alternatively Peazip offer full support for various lossless compression methods: https://peazip.github.io/paq-files-compression-utility.html
So wait..you want to take gif, apng, webp Sources and FURTHER compress them? Why? They won't be directly usable as their native formats then. Or is this simply another exercise?
Scott -
I just saw some compressors for those formats and wonder if any of them were lossless.
https://www.bing.com/search?q=gif+compressor&cvid=89281fb828244a3c8c26a2a22b5b245c&gs_...ANNTA1&PC=U531
https://www.bing.com/search?q=apng+compressor&qs=n&form=QBRE&sp=-1&lq=0&pq=apng+compre...&ghacc=0&ghpl=
https://www.bing.com/search?q=animated+webp+compressor&qs=n&form=QBRE&sp=-1&lq=0&pq=an...&ghacc=0&ghpl=
You could also look on Google. -
You asked about something else - lossless compression for GIF+APNG+WEBP - and you already received few suggestions but after all seem you ask NOT for compression but for OPTIMIZERS - this something else. You should decide what is your goal as it seem this is not clear neither for you nor for us...
Perhaps those are just the size you should already expect them to be. 95MB is not unreasonable for hundreds or thousands combined, nor is it for even 1 pic if that pic is super-high-rez. You are giving no context here.
Scott -
And how big (filesize) were those clips originally? Context.
Scott -
One of them was 53.6 MB and I used Shutter Encoder to make it into a gif which was 450MB.
Yes, GIF is an inefficient format compared to h264, h265. With no advanced intraframe compression and No real interframe compression algorithms, it's no surprise. For such material, gif is simply not a good choice, and likely neither is apng or webp. All of those make sense for animated stills, but not for videos, yet you're trying to fit videos into them.
Scott -
No, you don't understand - you can use ZPAQ but don't expect high gain.
Generally GIF offer 256 colors maximum per frame - if you wish to have more colors then you need go for special GIF encoder https://en.wikipedia.org/wiki/GIF?useskin=vector#True_color (i'm not even aware if such encoder exist as GIF is very old format affected by some patents in early time of internet). However if you can accept quality loss using 256 colors per frame then ANY other modern codec will give higher quality and higher compression gain - just change GIF to different format.
I still have no clue what is your real goal but this is not my circus and not my monkeys. -
I'm guessing ffmpeg and shutter encoder are those special ones? Anyway, how do I optimize animated images and videos without losing quality?
Stop guessing - read the material on the net and try out the best contenders yourself, using clear scientific methods.
Scott -
All right, I will. By the way, can you answer this?
https://forum.videohelp.com/threads/414018-Stop-Overriding-Files -
Why do you insist on answer after it was answered already? Also in VD2, exporting image sequences, you can choose to include frame number into an image file name, so after selecting different parts of the same video, frames will still have a unique names! You got that selection in the pop up window that you are looking at. You do not need timestamps, when you have that feature. It is a common image naming feature across hundreds of apps. It is an image sequence naming commonality. There is no need to come up with something extra.
It was asked by one of yours disguised nick name, I cannot keep up with the names, so I cannot google it for you.
I'm with you, @_AI_, more goofy obsession from yet another alias of a well-known troll.
Scott -
I mean for videos, not images. I want to automatically add timestamps/timecodes to the names of the output VIDEOS (e.g. mkv, mp4, mov) from Avidemux and VirtualDub2, not images.
Different Gifs
By The Enigma in forum Newbie / General discussionsReplies: 5Last Post: 20th Apr 2024, 12:38 -
Gifs/Apngs With Forced Subtitles
By Jay123210599 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2024, 13:46 -
Subtitles with Gifs, Apngs, and image sequences
By Jay123210599 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2023, 08:44 -
ffmpeg: How to overlay two gifs to play at once?
By Mugunga in forum Video ConversionReplies: 1Last Post: 1st Jun 2023, 07:51 -
Losslessly Convert 2.0 to 5.1
By koberulz in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2019, 11:05
