  1. How do you automatically rename or change the naming of the files in Avidemux and VirtualDub2 to prevent overwriting previous ones?
    I mean, how do I automatically add timestamps to the names of my output files?
  2. This can be tricky in "dos" - i use something like this:
    @set SAVESTAMP=%DATE:/=-%_%TIME::=-%
    @set SAVESTAMP=%SAVESTAMP:.=-%
    *example of usage in file name*
    "%~n1_%SAVESTAMP%_.mov"
    And btw - this is for scripting so if you can use mentioned applications from command line then it should be not a problem.
  3. TBH i've never ever used StaxRip...
