Results 1 to 17 of 17
    Mar 2009
    Good Afternoon.
    I have a MKV 4k file and I am trying to convert it to UHD disc. I am trying to keep the same auto track and just convert it to a disc.
    I tried dvdfab and the sound is not working properly. I tried Tsmuxer and it crashed. Does anyone have any suggestions. I really do appreciate it.
    Thank you
    General
    Complete name : G:\Star.Wars.Episode.V.The.Empire.Strikes.Back.198 0.mkv
    Format : Matroska
    Format version : Version 4
    File size : 54.6 GiB
    Duration : 2 h 7 min
    Overall bit rate : 61.4 Mb/s
    Frame rate : 23.976 FPS
    Movie name : Star.Wars.Episode.V.The.Empire.Strikes.Back.1980
    Encoded date : 2022-11-14 21:59:51 UTC
    Writing application : mkvmerge v71.1.0 ('Fortitude') 64-bit
    Writing library : libebml v1.4.4 + libmatroska v1.7.1
    Video
    ID in the original source medium : 4113 (0x1011)
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5.1@High
    HDR format : SMPTE ST 2086, HDR10 compatible
    Codec ID : V_MPEGH/ISO/HEVC
    Bit rate : 49.7 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.250
    Stream size : 44.2 GiB (81%)
    Writing library : ATEME Titan File 3.9.0 (4.9.0.0)
    Language : English
    Default : No
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : BT.2020
    Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
    Original source medium : Blu-ray
    Audio #1
    ID in the original source medium : 4352 (0x1100)
    Format : MLP FBA 16-ch
    Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
    Commercial name : Dolby TrueHD with Dolby Atmos
    Codec ID : A_TRUEHD
    Bit rate mode : Variable
    Bit rate : 3 979 kb/s
    Maximum bit rate : 5 181 kb/s
    Channel(s) : 8 channels
    Channel layout : L R C LFE Ls Rs Lb Rb
    Sampling rate : 48.0 kHz
    Frame rate : 1 200.000 FPS (40 SPF)
    Bit depth : 24 bits
    Compression mode : Lossless
    Stream size : 3.54 GiB (6%)
    Title : TrueHD 7.1 Atmos
    Language : English
    Default : Yes
    Forced : No
    Number of dynamic objects : 13
    Bed channel count : 1 channel
    Bed channel configuration : LFE
    Audio #2
    Format : DTS XLL
    Format/Info : Digital Theater Systems
    Commercial name : DTS-HD Master Audio
    Codec ID : A_DTS
    Bit rate : 4 007 kb/s
    Channel layout : C L R LFE Lb Rb Lss Rss
    Frame rate : 93.750 FPS (512 SPF)
    Bit depth : 24 bits
    Stream size : 3.57 GiB (7%)
    Title : DTS-HD MA 7.1
    Language : English
    Default : No
    Forced : No
    Mar 2008
    Did you use the latest version of TSMuxer?
    Look at some of the threads in the VH blu-ray forum, many have posted similar
    Mar 2009
    yes . I loaded it with tsmuxer and it crashes with an error 2 code
    Mar 2008
    You might need to produce the full TSMuxer log showing the error.
    Have you tried hardcoding the frame rate (24000/1001)
    Mar 2009
    hm... I have to change the frame rate? i didnot do that
    Mar 2008
    Well it's the same frame as reported in your mediainfo above ....
    Mar 2009
    Warning! HEVC codec is not standard for BD disks!
    Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: G:\Star.Wars.Episode.V.The.Empire.Strikes.Back.198 0.mkv
    Mar 2008
    I have a feeling it's something simple. Can you upload a 1 to 2 minute clip from your source
    and I'll try myself. I've downloaded the latest nightly from here
    https://www.videohelp.com/software/tsMuxeR
    The 2 or 3 short HDR/UHD demos I found in my PC have worked and created the blu-ray folder without issues
    Mar 2009
    i am sorry how would i be able do that ?
    thats so wierd
    Mar 2008
    Use Avidemux. If you don't have it, get it from here
    https://www.videohelp.com/software/AviDemux
    Use either installer or poratble version.
    Open it and drag in your source. Use the up and down buttons to navigate (or you can just drag the position cursor),
    use the A and B buttons to set the start and end points,
    leave everything on the left as-is,
    File/Save
    Upload your MKV clip
    Mar 2008
    It worked for me, but I got a warning about the MLP codec, which I think is related to the Atmos Audio
    Mar 2009
    [Attachment 72841 - Click to enlarge]
    I did the orignal file like this.
    Mar 2008
    A couple of things to try: add the frame rate specifically as I mentioned before,
    download the portable nightly version of TSMuxer from the software section
    Mar 2009
    Hi...
    I downloaded portable nightly version and it worked!
    Thank you very much
    Mar 2008
    Hi...
    Thank you very much
    You're welcome
  16. Member Ennio's Avatar
    May 2005
    Netherlands
    Eventhough latest tsMuxer can mux TrueHD without an embedded AC3 track into (UHD)BD, beware that it's not according to the official specs. A disk player may refuse to play it. Especially if it's a SONY.
    Should you encounter this behaviour, you can convert TrueHD (with or without Atmos) into a so-called "TrueHD+AC3" stream with eac3to. Which tsMuxer will accept on import and is (UHD)BD compliant.
