  1. Hi.
    I want to rip a BluRay movie to small file. I already have a remux from DVDFab, if I understand correctly, it's a lossless 1:1 copy of the film?
    I'd like to keep the size at 10GB maximum. I'm not satisfied with DVDFab. I tried VidCoder (HandBrake) but I'm not sure how to set it up. I wouldn't want to waste a whole day of stressing cpu.
    Audio weights 571MB so that leaves let's say 9GB for video.
    Here's MediaInfo:
    Format/Info                    : High Efficiency Video Coding
    Format profile                 : Main 10@L5.1@High
    HDR format                     : SMPTE ST 2086, HDR10 compatible
    Codec ID                       : V_MPEGH/ISO/HEVC
    Duration                       : 2 h 4 min
    Bit rate                       : 47.8 Mb/s
    Width                          : 3 840 pixels
    Height                         : 2 160 pixels
    Display aspect ratio           : 16:9
    Frame rate mode                : Constant
    Frame rate                     : 23.976 (24000/1001) FPS
    Color space                    : YUV
    Chroma subsampling             : 4:2:0 (Type 2)
    Bit depth                      : 10 bits
    Bits/(Pixel*Frame)             : 0.240
    Stream size                    : 41.7 GiB (89%)
    Writing library                : ATEME Titan File 3.9.0 (4.9.0.0)
    Language                       : English
    Default                        : No
    Forced                         : No
    Color range                    : Limited
    Color primaries                : BT.2020
    Transfer characteristics       : PQ
    Matrix coefficients            : BT.2020 non-constant
    Mastering display color primar : BT.2020
    Mastering display luminance    : min: 0.0001 cd/m2, max: 1000 cd/m2
    Title                          : MPEG-H HEVC Video / 47819 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
    Mar 2008
    Do you want to keep it at 4k and do you want to retain the HDR encoding ?
  3. Originally Posted by davexnet View Post
    Yes and yes!
    Feb 2006
    Originally Posted by rawyolks View Post
    Hi.
    Here's MediaInfo:
    Color space                    : YUV
    Bit depth                      : 10 bits
    Language                       : English
    Default                        : No
    Forced                         : No
    might try anydvd HD - https://forum.redfox.bz/forums/anydvd-hd-uhd-only.105/
    or CloneBD - https://www.videohelp.com/software/CloneBD
    Mar 2008
    Try Vidcoder like this, you can use the mouse to select a small area to do a test encode to check for bitrate, etc
