Closed Thread
    Mar 2009
    Good Afternoon.
    I have a MKV 4k file and I am trying to convert it to UHD disc. I am trying to keep the same auto track and just convert it to a disc.
    I tried dvdfab and the sound is not working properly. I tried Tsmuxer and it crashed. Does anyone have any suggestions. I really do appreciate it.
    Thank you
    General
    Complete name : G:\Star.Wars.Episode.V.The.Empire.Strikes.Back.198 0.mkv
    Format : Matroska
    Format version : Version 4
    File size : 54.6 GiB
    Duration : 2 h 7 min
    Overall bit rate : 61.4 Mb/s
    Frame rate : 23.976 FPS
    Movie name : Star.Wars.Episode.V.The.Empire.Strikes.Back.1980
    Encoded date : 2022-11-14 21:59:51 UTC
    Writing application : mkvmerge v71.1.0 ('Fortitude') 64-bit
    Writing library : libebml v1.4.4 + libmatroska v1.7.1
    Video
    ID in the original source medium : 4113 (0x1011)
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5.1@High
    HDR format : SMPTE ST 2086, HDR10 compatible
    Codec ID : V_MPEGH/ISO/HEVC
    Bit rate : 49.7 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.250
    Stream size : 44.2 GiB (81%)
    Writing library : ATEME Titan File 3.9.0 (4.9.0.0)
    Language : English
    Default : No
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : BT.2020
    Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
    Original source medium : Blu-ray
    Audio #1
    ID in the original source medium : 4352 (0x1100)
    Format : MLP FBA 16-ch
    Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
    Commercial name : Dolby TrueHD with Dolby Atmos
    Codec ID : A_TRUEHD
    Bit rate mode : Variable
    Bit rate : 3 979 kb/s
    Maximum bit rate : 5 181 kb/s
    Channel(s) : 8 channels
    Channel layout : L R C LFE Ls Rs Lb Rb
    Sampling rate : 48.0 kHz
    Frame rate : 1 200.000 FPS (40 SPF)
    Bit depth : 24 bits
    Compression mode : Lossless
    Stream size : 3.54 GiB (6%)
    Title : TrueHD 7.1 Atmos
    Language : English
    Default : Yes
    Forced : No
    Number of dynamic objects : 13
    Bed channel count : 1 channel
    Bed channel configuration : LFE
    Audio #2
    Format : DTS XLL
    Format/Info : Digital Theater Systems
    Commercial name : DTS-HD Master Audio
    Codec ID : A_DTS
    Bit rate : 4 007 kb/s
    Channel layout : C L R LFE Lb Rb Lss Rss
    Frame rate : 93.750 FPS (512 SPF)
    Bit depth : 24 bits
    Stream size : 3.57 GiB (7%)
    Title : DTS-HD MA 7.1
    Language : English
    Default : No
    Forced : No
