Hi guys,
I would like to save disk space and
Just curious about what has better quality:
Sizes of both are pretty much the same:
- DTS Core @ 24 bit - loosy
- FLAC @ 16 bit - lossless, converted from 24 bit DTS-HD MA
FLAC @ 16 bit ~ DTS Core @ 24 bit
From what I understand, 24 bit in DTS Core may make sound more spacious in comparison to 16 bit lossless FLAC. But can be wrong.
Thanks!
24 bit audio isuseful in recording, where so many plugin effects are used that the quantization errors can add up to be audible. But it's been demopnstarated in double blind tests that audiophiles couldn't hear a difference (there's a study in the AES journal and it's been repeated). IMO 24 bit audio is a waste of space.
The thing is, the LSB in 16 bit audio is better that -90 dB, and most any decent DAC can get better than -80 dB spuriae free. If you think your speakers or headphones are that clean think again. Look at some speaker waterfall plots, and remember that 0.2% distortion for a speaker is very, very good, and that's not even -60 dB.
The funniest thing to me is how many old recordings done on analog tape are being released in 24 bit. The best dynamic range you can get from analog tape is 80dB, and 60-65 is more typical.
ANd that thing about 24 bit making it sound more spacious is very misleading. EVen if 24 bit really had the benefits all those so called golden ears claim, that would only be true if you had an exceptional recording, and those are very rare.
So my answer is that they sound exactly the same unless you messed up the conversion or you're one of those self deluded "golden ears". -
The lossy core of the lossless DTS-HD codec doesn't have a fixed bit depth. Whenever you see software label a lossy codec such as DTS as having a fixed bit depth such as 24, it's technically wrong. I'm certain what the "bit depth" in the DTS codec information really means is that's what the original DTS-HD encoder encoded the lossless audio stream to and added that metadata to the DTS core so now that's what you see as the "bit depth" even though it's technically wrong, but don't quote me on that.
Sample rate is quite important factor to describe overall quality - with help of noiseshaping you can easily provide 20+ bit perceived quality over 44kHz 16 bit PCM, if you can provide for example 192kHz sample rate then with help of noiseshaping you can easily achieve 24 bit quality from 8 bit PCM. So in general there more factors involved.
Why the rippers usually change the original bit of depth (DTS Core)?
By Enrik in forum AudioReplies: 10Last Post: 26th Jul 2019, 18:53 -
Bit of help with DTS-X and other formats
By vinylpusher1 in forum AudioReplies: 0Last Post: 22nd Apr 2019, 06:25 -
converting to 24 bit DTS using ffmpeg, but the getting 16 bit
By jbiribi in forum AudioReplies: 12Last Post: 17th Mar 2018, 23:34 -
Blu-ray Dolpy Atmos 7.1 to Flac 24-bit 7.1?
By Computerman1 in forum Blu-ray RippingReplies: 12Last Post: 10th Jan 2018, 07:28 -
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 10:22
