Results 1 to 13 of 13
    Mar 2018
    Brasil
    I used this command --> "ffmpeg -i Journey1.wav -strict -2 -vn -b:a 1536k -sample_fmt s32 -f dts final.dts" but the converted audio is always 16 bit. Why? With -sample_fmt s24 I get an error saying the command doesn't exist, and with -sample_fmt s32 I'm getting a 16 bit audio.
  2. Anonymous
    Guest
    Lossy audio actually does not have bitdepth. And the bitdepth flag in the frame headers may be ignored by the decoders.
    If I remember correctly, you can use eac3to for patching the DTS frame headers to 24-bits.
    But now, some questions... is your source .WAV file 16-bits, 24-bits, or 32-bits? ffdcaenc supports all of these.
    Also, how many channels does your source .WAV file have? If the answer is 1 or 2, then 1536kbps is overkill,
    and if the answer is 6, even 1509kbps may be unnecessarily high as well — except if your goal is DVD-authoring or playback in a standalone (hardware) player.
    Mar 2018
    Brasil
    My original source was 5.1 DTS 24 bit 1536 kbps. I converted to 5.1 PCM 24 bits 6900 kbps to use in premiere. Rendered in PCM with the same specs. Now, I want to convert this WAV PCM to his orginal format, DTS, with the same specs from the original source.
  4. Anonymous
    Guest
    Then you'd better switch to ffdcaenc.
    I use ffmpeg only for decoding, demuxing and remuxing, so I have no idea of how good it is at using libdcaenc.
    I have just checked (with both LeeAudBi and MediaInfo) some DTS files that I created with ffdcaenc many moons ago, and all of them are (wisely) marked as 24-bits, even when the sources were ordinary 16-bit stereo .WAV files.
  5. DCA encoder capabilities:
    Encoder dca [DCA (DTS Coherent Acoustics)]:
        General capabilities: exp
        Threading capabilities: none
        Supported sample rates: 8000 16000 32000 11025 22050 44100 12000 24000 48000
        Supported sample formats: s32
        Supported channel layouts: mono stereo quad(side) 5.0(side) 5.1(side)
    DCA (DTS Coherent Acoustics) AVOptions:
      -dca_adpcm         <boolean>    E...A... Use ADPCM encoding (default false)
    Not sure about 24 bit encoding within DTS standard (it may imply to use different profile - check if DTS core is capable for something more than 16 bit audio - perhaps you need to use extension to core).
    Mar 2018
    Brasil
    Ok, I'll try to use ffdcaenc. Can I use the same code I used in ffmpeg?
    Mar 2018
    Brasil
    I think so, because my original dts audio was 24 bit. In it information was writen 24 bit
  8. Anonymous
    Guest
    Nope, because ffdcaenc is much simpler to use.
    [C:\]
    => ffdcaenc -h
    FFDCAENC --- experimental 'Coherent Acoustics' compressor.
    Usage:
      ffdcaenc -i <input.wav> -o <output.dts> -b <bitrate_kbps>
    Optional:
      -l  Ignore input length, can be useful when reading from stdin
      -e  Switch output endianess to Little Endian (default is: Big-Endian)
      -r  Reduced Bit Depth for DTS CD format (default is: Full Bit-Depth)
      -h  Print this help screen
      -c  Overwrite the channel configuration (default is: auto-selection)
      -f  Add an additional LFE channel (default: used for 6-channel input)
      -m  Multiple Mono input files (default: -i for multi-channel input file)
           Use -0 <input.wav> -1 <input.wav> etc. (up to -5) Channels are in ITU order:
           0,1,2,3,4,5 --> LF, RF, C, LFE, LS, RS
           The following mono input file combinations are supported:
                    1.0             -2 center.wav
                    1.1             -2 center.wav -3 lfe-wav
                    2.0             -0 left.wav -1 right.wav
                    2.1             -0 left.wav -1 right.wav -3 lfe.wav
                    3.0             -0 left.wav -1 right.wav -2 center.wav
                    3.1             -0 left.wav -1 right.wav -2 center.wav -3 lfe.wav
                    4.0             -0 left.wav -1 right.wav -4 ls.wav -5 rs.wav
                    4.1             -0 left.wav -1 right.wav -4 ls.wav -5 rs.wav -3 lfe.wav
                    5.0             -0 left.wav -1 right.wav -2 center.wav -4 ls.wav -5 rs.wav
                    5.1             -0 left.wav -1 right.wav -2 center.wav -4 ls.wav -5 rs.wav -3 lfe.wav
      -v  Show version info
    REMARKS:
    The input or output filename can be "-" for stdin/stdout.
    The bitrate is specified in kilobits per second and may be rounded up
    -- use floating-point values for bitrates that are not a multiple of 1 kbps.
    Because the encoder uses a 4-byte granularity, i.e., 32 bits per audio frame
    (with 512 samples/frame), the ACTUAL bitrate will always be a multiple of:
    3         kbps for     48 kHz
    2.75625   kbps for   44.1 kHz
    2         kbps for     32 kHz
    1.5       kbps for     24 kHz
    1.378125  kbps for  22.05 kHz
    1         kbps for     16 kHz
    0.75      kbps for     12 kHz
    0.6890625 kbps for 11.025 kHz
    0.5       kbps for      8 kHz
    -- NOTICE: the values 377.25, 503.25, 754.5 and 1509.75 AT _48kHz_ are exceptions.
    * Available channel-layouts:
      -  1: A
      -  2: A, B
      -  3: L, R
      -  4: (L+R), (L-R)
      -  5: Lt, Rt
      -  6: FC, FL, FR
      -  7: FL, FR, BC
      -  8: FC, FL, FR, BC
      -  9: FL, FR, BL, BR
      - 10: FC, FL, FR, BL, BR
      - 11: CL, CR, FL, FR, BL, BR (not supported)
      - 12: FC, FL, FR, BL, BR, OV (not supported)
      - 13: FC, BC, FL, FR, BL, BR (not supported)
      - 14: CL, FC, CR, FL, FR, BL, BR (not supported)
      - 15: CL, CR, FL, FR, SL1, SL2, SR1, SR2 (not supported)
      - 16: CL, FC, CR, FL, FR, BL, BC, BR (not supported)
    Mar 2018
    Brasil
    [C:\]
    => ffdcaenc -h
    Usage:
    Optional:
                    1.0             -2 center.wav
    REMARKS:
    3         kbps for     48 kHz
    2         kbps for     32 kHz
    1.5       kbps for     24 kHz
    1         kbps for     16 kHz
    0.5       kbps for      8 kHz
      -  1: A
      -  2: A, B
      -  3: L, R
      -  4: (L+R), (L-R)
      -  5: Lt, Rt
      -  6: FC, FL, FR
      -  7: FL, FR, BC
      -  8: FC, FL, FR, BC
      -  9: FL, FR, BL, BR
    Ok, I will try
  10. Originally Posted by jbiribi View Post
    Based on ETSI TS 102 114 V1.4.1 (2012-09) seem that DTS core DCA shall be capable to encode 24 bit samples.
    5 Core Audio
    The DTS core encoder delivers 5.1 channel audio at 24 bits per sample with a sampling frequency of up to 48 kHz.
    So 16 bit outcome may be internal limitation for DCA encoder implementation.
    Mar 2018
    Brasil
    [C:\]
    => ffdcaenc -h
    Usage:
    Optional:
                    1.0             -2 center.wav
    REMARKS:
    3         kbps for     48 kHz
    2         kbps for     32 kHz
    1.5       kbps for     24 kHz
    1         kbps for     16 kHz
    0.5       kbps for      8 kHz
      -  1: A
      -  2: A, B
      -  3: L, R
      -  4: (L+R), (L-R)
      -  5: Lt, Rt
      -  6: FC, FL, FR
      -  7: FL, FR, BC
      -  8: FC, FL, FR, BC
      -  9: FL, FR, BL, BR
    Ok, I will try
    I used this code --> ffdcaenc -i "D:\Desktop\Downloads\Journey.wav" -o output.dts -b 1536
    I got this message --> Could not open or parse "D:\Desktop\Downloads\Journey.wav". Error: Data chunk size is invalid!
  12. Anonymous
    Guest
    Two things:
    1) what is the size of "Journey.wav"? If the answer is 'greater than 4 gigbytes', then you'll have to feed ffdcaenc from stdin and use the -l (ignore length) switch.
    2) Are you sure "D:\Desktop\Downloads\Journey.wav" is a valid path string?
    Mar 2018
    Brasil
    Two things:
    Adding -l worked for me. The wav have 10,3 gb. Thank you very much for your help!!
