I have recently downloaded a .AVI file that I want to convert to VCD, I am trying TMPGenc to do so! When I attempt to open the video portion, I get a message that the file format is not supported. I have installed the VFAPI plug-in, and the DiVX Cdec, and NEMO codec, and no luck! Any ideas for converting this??????????
Please open the avi in VirtualDub, select file > file information and post the file properties. Also try to increase the priority of the directshow multimedia file reader in TMPGEnc. >options > enviromental settings > VFAPI plugins.
MAYDOG, I had the same problem just change the direct show priority in tmpgenc. If you re-read the first guide under converting go to the bottom of the guide it says problems with tmpgenc click here.and if you do it will explain in detail on how to change the direct show priority or something like that.Good luck let me know how it turns out
vcd4me is correct. In the environment settings of TMPGEnc under VFAPI settings, bump up the priority settings of the DirectShow Filters higher than anything else in the list. By default it s at zero by the way. Mine is at 6 I think.
This also takes care of some of the sound synching problems encountered. -
AGUILLION, just out of curiosity why did you set it so high. the guide says to up it to 1 or 2. I really don't know what mine is set at(1 or 2) but it works everytime.
I open an AVI> File in VirtualDub and come back with an error: couldn’t locate decompressor for format “mp43” (Microsoft high-speed MPEG-4V3). Can someone help me? Thanks 50-year-old beginner.
Hey OLD RED :lol: Just kiding about the old part> did you do what I posted above change the direct show priority look up and read what to do! also in the future you should just make your own post I just happened to find this because I was checking up on people that I give advice to. Let me know ho you make out.Your Friend ED
We were all NEWBIES once and the only stupid question is the one that's not asked?
Problems with an avi to MKV conversion
By Paxmilitaris in forum Video ConversionReplies: 0Last Post: 21st Oct 2011, 15:11 -
DVD to avi conversion problems
By carlmart in forum Video ConversionReplies: 6Last Post: 19th Apr 2011, 15:01 -
Having problems with my .MKV conversion (to .AVI)
By triptiks in forum ffmpegX general discussionReplies: 2Last Post: 16th Jul 2008, 23:29 -
Better methods of AVI to VCD conversion?
By HerronScott in forum Video ConversionReplies: 3Last Post: 25th Oct 2007, 00:51 -
By olson311dude in forum Video ConversionReplies: 14Last Post: 9th Oct 2007, 05:27
