  1. I have recently downloaded a .AVI file that I want to convert to VCD, I am trying TMPGenc to do so! When I attempt to open the video portion, I get a message that the file format is not supported. I have installed the VFAPI plug-in, and the DiVX Cdec, and NEMO codec, and no luck! Any ideas for converting this??????????
    Feb 2001
    Berlin, Germany
    Please open the avi in VirtualDub, select file > file information and post the file properties. Also try to increase the priority of the directshow multimedia file reader in TMPGEnc. >options > enviromental settings > VFAPI plugins.
  3. If it opens up in vdub...frame serve it into tmpg.
  4. MAYDOG, I had the same problem just change the direct show priority in tmpgenc. If you re-read the first guide under converting go to the bottom of the guide it says problems with tmpgenc click here.and if you do it will explain in detail on how to change the direct show priority or something like that.Good luck let me know how it turns out
  5. vcd4me is correct. In the environment settings of TMPGEnc under VFAPI settings, bump up the priority settings of the DirectShow Filters higher than anything else in the list. By default it s at zero by the way. Mine is at 6 I think.
    This also takes care of some of the sound synching problems encountered.
  6. AGUILLION, just out of curiosity why did you set it so high. the guide says to up it to 1 or 2. I really don't know what mine is set at(1 or 2) but it works everytime.
  7. I open an AVI> File in VirtualDub and come back with an error: couldn’t locate decompressor for format “mp43” (Microsoft high-speed MPEG-4V3). Can someone help me? Thanks 50-year-old beginner.
  8. Hey OLD RED :lol: Just kiding about the old part> did you do what I posted above change the direct show priority look up and read what to do! also in the future you should just make your own post I just happened to find this because I was checking up on people that I give advice to. Let me know ho you make out.Your Friend ED
    We were all NEWBIES once and the only stupid question is the one that's not asked?
