  1. Ok...I got a vcd and it won't play on my computer. I get something called a "MMSYSTEM281" error and something about "installing a driver which can play this type of file".
    Any help would be greatly appreciated...
  2. As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. can someone help me in encoding avi to vcd format (mpeg)
    1) i used v-dub to extract the audio as a wav then saved it
    2)went in tmpenc and coverted the avi to mpeg input the wav file as audio
    3) encodin went fine using tempenc --NO errors
    4) then i tried to play the mpeg file in media player but only the audio worked no video (black SCREEN)
    any suggestions
  4. Hijacked thread!
  5. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Haven't i seen aguz86's message before? like say maybe http://forum.vcdhelp.com/viewtopic.php?t=88521
