Ok...I got a vcd and it won't play on my computer. I get something called a "MMSYSTEM281" error and something about "installing a driver which can play this type of file".
Any help would be greatly appreciated...
This might (or might not) help:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q141349As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
can someone help me in encoding avi to vcd format (mpeg)
1) i used v-dub to extract the audio as a wav then saved it
2)went in tmpenc and coverted the avi to mpeg input the wav file as audio
3) encodin went fine using tempenc --NO errors
4) then i tried to play the mpeg file in media player but only the audio worked no video (black SCREEN)
any suggestions -
Hijacked thread!
Haven't i seen aguz86's message before? like say maybe http://forum.vcdhelp.com/viewtopic.php?t=88521
