Results 1 to 11 of 11
    Apr 2002
    scotland(Glasgow)
    i have been trying to rip a dvd for weeks now but havin no luckif there is anyone out there that can help me it would be much appreciated.
    i am using smatripper to rip the dvd and nero to burn it but cant get it to m work on my dvd player but it should.
    the files that i am burning are as follows
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VIDEO_TS.VOB
    VTS_01_0.BUP
    VTS_01_0IFO
    VTS_01_0VOB
    VTS_01_1>VOB etc etc
    are any of these files copy protected and maybe thats why it wont play
    PLEASE HELP
    Jul 2001
    Maryland
    They are all unless you patched them
    Apr 2002
    scotland(Glasgow)
    so all of the files are copy protected and how do i patch them
    Apr 2002
    scotland(Glasgow)
    can anyone help me out here :lol:
  5. After you rip the dvd, you have to run the vob files thru dvd2avi, then frameserve into TMPEG to make a VCD with Nero.
    Apr 2002
    scotland(Glasgow)
    so i make the dvd a vcd then burn it onto a dvdr disc and will that play on most dvd players
    Apr 2002
    Florida
    no you have to encode the vob files to mpeg and then use what ever burning softwhere you use to make a dvd (you have to RE-code the files into a nonencripted format) basicly what you said without burning the vcd
    Static is in the minds and hearts of all mankind the sad part is... that we never fully comprehend the concept that is static.
    Apr 2002
    scotland(Glasgow)
    what i am looking for is how to copy a DVD onto a DVDR i am not wanting to make a VCD
  9. Have you followed the guides? Start with a really short easy movie to get the hang of it.
    Here's how I do it:
    1) DVDDecrypter to HD
    2) IfoEdit open the movie .ifo file (for the main movie)
    3) Select the "VOB" button under the menu button
    4) Select all options but the top one and split DVD
    5) Hit strip button and select one sound track and one language
    6) Hit okay or whatever button is there and select the VOB-ID's you need
    7) Let it run for a bit and then close Ifoedit
    8) Open IFOedit, load the new Video_TS file you created and select GET VTS sectors
    9) Press PlayDVD or DVDPlay
    10) If it works okay, you can try the video_ts in powerDVD 4.0
    11) If that's good then burn it in Nero 5.5.7.8+
    May 2001
    If you ripped the DVD properly, then you can just move these files back onto a DVD-R using NERO (use version 5.5.8.0 - it has a DVD-Video template). The DVD-R you are trying to make has to have the video files in a directory named VIDEO_TS. Also, set NERO to be ISO9660 compliant (don't use Joliet file naming extentions).
    I'm assuming that you have ripped properly... will any of the VOBs play with Windows Media Player? If not, then you need to read how to rip properly.
    Apr 2002
    scotland(Glasgow)
    doing it the way you said will that take out the protection from the dvd
