i have been trying to rip a dvd for weeks now but havin no luckif there is anyone out there that can help me it would be much appreciated.
i am using smatripper to rip the dvd and nero to burn it but cant get it to m work on my dvd player but it should.
the files that i am burning are as follows
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.BUP
VTS_01_0IFO
VTS_01_0VOB
VTS_01_1>VOB etc etc
are any of these files copy protected and maybe thats why it wont play
PLEASE HELP
Results 1 to 11 of 11
so all of the files are copy protected and how do i patch them
After you rip the dvd, you have to run the vob files thru dvd2avi, then frameserve into TMPEG to make a VCD with Nero.
so i make the dvd a vcd then burn it onto a dvdr disc and will that play on most dvd players
no you have to encode the vob files to mpeg and then use what ever burning softwhere you use to make a dvd (you have to RE-code the files into a nonencripted format) basicly what you said without burning the vcd
Static is in the minds and hearts of all mankind the sad part is... that we never fully comprehend the concept that is static. -
what i am looking for is how to copy a DVD onto a DVDR i am not wanting to make a VCD
Have you followed the guides? Start with a really short easy movie to get the hang of it.
Here's how I do it:
1) DVDDecrypter to HD
2) IfoEdit open the movie .ifo file (for the main movie)
3) Select the "VOB" button under the menu button
4) Select all options but the top one and split DVD
5) Hit strip button and select one sound track and one language
6) Hit okay or whatever button is there and select the VOB-ID's you need
7) Let it run for a bit and then close Ifoedit
8) Open IFOedit, load the new Video_TS file you created and select GET VTS sectors
9) Press PlayDVD or DVDPlay
10) If it works okay, you can try the video_ts in powerDVD 4.0
11) If that's good then burn it in Nero 5.5.7.8+ -
If you ripped the DVD properly, then you can just move these files back onto a DVD-R using NERO (use version 5.5.8.0 - it has a DVD-Video template). The DVD-R you are trying to make has to have the video files in a directory named VIDEO_TS. Also, set NERO to be ISO9660 compliant (don't use Joliet file naming extentions).
I'm assuming that you have ripped properly... will any of the VOBs play with Windows Media Player? If not, then you need to read how to rip properly. -
doing it the way you said will that take out the protection from the dvd
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping a DVD
By andreltr in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 09:29 -
Ripping A DVD
By Nitro89 in forum DVD RippingReplies: 4Last Post: 16th Feb 2009, 06:41 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
HD DVD Ripping
By joco200 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 15:14
