  1. Hi im new first i want to tell you what i want to do i want to take a dvd put it on my computer then do all that converting stuff then burn it on a CD then play it on my PSX that has a mod chip so i can watch it on TV. Ok well i followed this tut http://www.vcdhelp.com/pinoy2201sdvdrippinguide.htm i did everything except cut the file into 2 . Ok so now i have this big mpg file thats 3.41 GIG and im not sure on what to do i know you cant burn that much on a CD so can somone please help me out?
  2. Alright, you have this huge file that is around or almost 4 gig. Open the movie file back up with TMPGEnc, and use the wizard that they provide when the program opens to convert it to VCD or SVCD. I would have to reccomend VCD for you since SVCD requires more space. Using this process you should be able to cut down the size of the file. Howeverm I am not going to say this will fit on one CDR, it might not. It all just depends on the size of the movie, and the way you format the audio.
    Wow Dude, Wow.
