    Aug 2006
    Canada
    I have a brand-new computer and I would really be happy if someone provide me the best choice of codecs for my computer, so I dont roam around internet and download other crappy codecs that screw my computer up.
    (Sorry for the little bad-language, but it is really frustrated to get the comp. screw up with junky codec)
    Thanks so much
  2. i have only installed 2 , latest xvid and divx, ive never really needed anything other
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Don't install any codec packs and don't just blindly install a bunch of codecs just incase you might need them...that is about the only safe rule. Aside from that, whenever you come across a file that doesn't play, then download and install the codec needed for that file. There is a codec list in the Tools section.
    Google is your Friend
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    With most files you can determine which codec is required to play it with Gspot.
    NO CODEC PACKS !!! NO !!!
  6. Member Paul_G's Avatar
    Yes totally avoid codec packs (learnt the hard way), they may work now but will **** you over in the end.
  7. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I tried telling that to another poster a few weeks ago and he's like "Works great for me"....
    Yeeeeep, right up until 6 months from now when you're asking why your video is upside down....
