  1. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    FWIW, there are links to "unofficial" DST update utilities for Win95/98/ME/NT here:
    http://www.mdgx.com/files/Q931836.EXE (Win95/98/ME)
    http://www.mdgx.com/files/NT931836.EXE (WinNT 4.0)
    I've seen the "mgdx.com" updates mentioned on other sites in "good terms." But of course, they are unofficial fixes (use at your own risk). For 95/98/ME users, the Date/Time Properties window will open up. YOU MUST click "OK" to incorporate the fix.
    I went ahead and installed it on my own Win98SE partition and no virus windows opened up (grin). So, we'll see what happens on March 11th.
    May 2004
    Thank you much. I have patched my eMac in Panther with Apple's fix and this fixes VPC Win98SE.
  3. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    I'm curious to see what happens when the unpatched PCs WOULD have shifted to DST.
    Nothing can stop me now, 'cause I don't care anymore.
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    For home PC's It's not really that big a deal as far as I know.. For servers on the other hand it is for timestamps etc. The timestamps on the posts for the forum would be off by an hour here if it wasn't patched, not really a big deal for this site but for site where the correct time is imporatnat that of course would be a problem.
    This is the official Microsoft way to fix anything prior to XP SP2:
    Microsoft Windows 95, 98, ME, NT, 2000, XP (no SP), XP SP1
    Microsoft has advised that Outlook users should update Windows and Outlook at the same time. See Microsoft Outlook below.
    These no-longer-supported versions of Windows should use the tzedit.exe utility to reset the Daylight Time change dates for your time zone. Here are the instructions, and also links to download tzedit.exe in case you can't find it on your Windows installation CD. Versions of tzedit are available for all levels of Windows, from 95 to XP. Tzedit is compatible with all application software. The alternative timezone.exe utility should not be used, because it is not compatible with some applications such as Lotus Notes.
    Using tzedit.exe avoids the need for (risky!) registry modifications described elsewhere. (It makes them for you, correctly, under the covers.)
    1. Download and install the correct version of tzedit for your operating system from one of these sources:
    * Locate tzedit.exe on your Windows installation CD. (Best!)
    * Download tzedit.exe for Windows NT, 2000, XP, 2003 from Microsoft here http://download.microsoft.com/download/5/8/a/58a208b7-7dc7-4bc7-8357-28e29cdac52f/TZEDIT.exe . When prompted, you should save this on disk somewhere, such as your desktop. Double-click it to run the self-extracting installer program, which by default will install the program into folder C:\Program Files\TZEdit.
    * Download tzedit.exe for Windows 95, 98, ME here http://www.uic.edu/depts/accc/systems/daylight/TZeditWin98.exe . When prompted, you should save this on disk somewhere, such as your desktop. Double-click it to run the self-extracting installer program, which by default will install the program into folder C:\Program Files\TZEdit. This version is intended for Windows 98, but has been found to run fine on Windows 95 and Windows ME as well. (Note: This ftp://ftp.microsoft.com/services/technet/samples/ps/Win98/Reskit/CONFIG/ is a copy of Microsoft's original tzedit.exe for Windows 95, 98, ME which we have downloaded for you because that particular server at Microsoft seems to be swamped much of the time.)
    2. Start up the tzedit program by double-clicking tzedit.exe.
    3. In the "Windows Time Zone Editor" window, the time zone you are editing should be highlighted. For instance, for Chicago it should be "(GMT-06:00) Central Time (US & Canada)". (Note that tzedit only edits the settings for a time zone; it does not put any time zone into effect. You do that via Control Panel.)
    4. Click the Edit button.
    5. In the "Edit Time Zone" window:
    * Make sure that Automatically set Daylight Saving Time is checked.
    * Change the Start Day to Second, Sunday, March, 02:00:00
    * Change the Last Day to First, Sunday, November, 02:00:00
    * Don't change anything else. Click OK and Close to finish.
    If this computer is moved between time zones, such as a laptop that is carried between Chicago and New York, repeat the above changes within the tzedit program for each time zone your computer might visit.
    6. Do not skip these remaining steps, or your new changes will not take effect.
    Click Start --> Settings --> Control Panel --> Date/Time --> Time Zone (tab)
    7. Select some other time zone besides yours, i.e. any time zone other than (GMT-06:00) Central Time (US & Canada). Click Apply.
    8. Now select your time zone again, i.e. (GMT-06:00) Central Time (US & Canada). Click OK.
    Links:
    * Google Groups http://groups.google.com/group/microsoft.public.win98.gen_discussion/msg/1c7500d85821d260?hl=en& : Win98 Daylight Savings Time Manual Update Required
    * Microsoft Knowledge Base Article 914387 http://support.microsoft.com/?kbid=914387 How to configure daylight saving time for the United States in 2007. (This page opens better in IE browser.)
    I did this on my Windows XP SP1 today.
