Good evening.
I have some old programs that run with Win95 and Win98 but not with WindowsXP.
Is there any way to run those programs with WindowsXP?
Thank you for your help.
Cheers.
Results 1 to 10 of 10
They may be DOS (Disk Operating System) programs, which usually won't run in XP (Or Vista or W2000). You can try a DOS emulator like this: http://sourceforge.net/projects/dosbox Or do a internet search for ' run dos programs on xp ' or ' dos emulator xp ' and filter through them for something that might work.
Right-click on the program icon and select Properties,then select Compatibility.
If they were designed for DOS then you need DOSBox. -
VirtualPC, VirtualBox -- install old OS, run software -- the end.
I do this too.Want my help? Ask here! (not via PM!)
You can also create dual boot Win98/WinXP or Win95/WinXP if you still have Win98 or Win95 install discs. I have a dual boot Win98/Win2k for that very reason. Then I just boot to Win98 to run older programs and boot to Win2k for everything else. Note creating such a dual boot system requires the older OS be installed first.
Thank you to everybody that answered to my request.
But due to my knowledges they were not enough explained, so I didn't profit them.
Anyway thank you and till the next. -
Download Virtual PC from Microsoft. Install Virtual PC. Once installed, you will need the install discs from Windows 95 or 98 and install the operating system in the virtual pc. Once installed, install your software, and you are done.Originally Posted by JomapilBelieving yourself to be secure only takes one cracker to dispel your belief.
Dv8Ted2 your explanation was very perfect.
I understood everything. Within 2 or 3 days I'll try the process.
Thank you very much.
Cheers.
installing win95 on hd that has xp
By mac71671 in forum ComputerReplies: 15Last Post: 18th Feb 2009, 20:08 -
Remember your desktop icon layout for WIN XP..like win95 ezdesk? [RESOLVED]
By vhelp in forum ComputerReplies: 6Last Post: 7th Jan 2009, 10:22 -
Are there any updated browsers for WIN98?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Oct 2008, 12:54 -
Ipod and Win98?
By capman21 in forum ComputerReplies: 2Last Post: 27th Sep 2007, 12:04 -
I have to ask again, trying to installing Win98.
By capman21 in forum ComputerReplies: 45Last Post: 23rd Jun 2007, 12:38
