Offhand, I don't think there's a preset...
How about copying your mono track so you now have a left and right channel then putting an effect on them?
Or repost and find out how to save with winamp -
Import the audio, add a new audio track, copy the contents of the first track into the second, and change one track from "Mono" to "Left Channel" and the other from "Mono" to "Right Channel," then export the wav.
Here we go again...
https://forum.videohelp.com/viewtopic.php?t=320601
Scott -
This would still be a mono track. Just utilizing both speakers.Originally Posted by jdachik
True. But you can add a little reverb to one channel and boost up the midrange on the other, for example. You just need to experiment a little.This would still be a mono track. Just utilizing both speakers.
ha ha...that's what I was saying...even slide a track right a tad for that "stereophonic" sound...lmaooooo
Since you start with a mono track, that's as far as you can go. Once mono, always mono. Like said in this and your mirror thread, by applying clever filtering, it may appear as somewhat stereoish, but it won't ever be stereo.Originally Posted by rijir2001
A simple trick is to delay one channel by some small amount, like 0.1 s or less. Same thing as "Wide stereo" found on some CD players.
/Mats
FFmpeg / FFmbc ---> 8 Mono track to 1 Stereo
By elmuz in forum Video ConversionReplies: 2Last Post: 13th Jun 2011, 07:06 -
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 06:45 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
Audacity - Noise Removal & 2.0 mono tracks
By ecc in forum AudioReplies: 7Last Post: 28th Feb 2008, 10:38 -
create pseudo stereo from mono track..
By nopk in forum RestorationReplies: 14Last Post: 8th Dec 2007, 18:31
