    Mar 2006
    Denmark
    I'm doing a small project, and on of the requirements is that the video has to be MPEG2 24bit!
    When i work in vegas, it seems like i'm working in 32bit, and in the export menu for the MainConcept MPEG2 Exporter menu, i dont see a option for exporting to 24bit.
    Are MPEG2 always 24bit?
    Are there any tools that can detect/read the color bits, to dertermine what colorbits the file uses?
    Greetings, jot
    Apr 2004
    Miskatonic U
    32 bit is usually only for formats that support an alpha channel (the extra 8 bits being for the alpha mask) and some lossless codecs. If there is no options to select, then assume 24 bits. Mpeg2 for DVD is 24 bit.
    Read my blog here.
    Aug 2002
    cleveland, oh
    Try GSpot see tools on left
    Mar 2006
    Denmark
    jameshgross, GSPOT was my first try.. i coundt find any information about the bits specifically'
