is there a software that can do this?
Results 1 to 9 of 9
thank you ,but what software can do this?Originally Posted by jimmalenko
If in doubt, Google it.
DLP : DVD Lab Pro. One of the main reasons people start worrying about closed GOPs is the warning DLP gives when author open GOP encoded mpegs. I was just taking a punt that this might be what prompted your question.
Read my blog here.
The Teco Bitrate Viewer (http://www.tecoltd.com) can do this in the commercial version without re-encoding the video. It's been a very long time since I did this with it and I only did it once or twice with some SVCD testing I did some years ago, but it is possible. The free version of the Bitrate Viewer can't do this at all. The free version has very limited functionality compared to the commercial version. It's worth stating too that you must demux the video to do this as the Bitrate Viewer can only modify video only streams.
Why do you even need to do this? Are you getting a warning message or something?
Open GOPs should be OK in the context of DVD authoring (I think the point guns1inger was getting around to making).
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 16:29 -
MPEG document describing 'open GOP' in detail?
By Alex_ander in forum Video ConversionReplies: 7Last Post: 9th Jun 2008, 14:49 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 13th Feb 2008, 00:14 -
ES Video and GOP timecode
By arturo83 in forum DVB / IPTVReplies: 8Last Post: 21st Aug 2007, 07:57 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 19:08
