Ok i have a movie that is a .mkv that i want to mux to mp4 the problem is that when its doen it plays fine but the seeking is buggert after doing some reading it seams it a problem with open gop. I dont realy want to re-encode the video so i want th know if there is a way i can fix it without re-encoding or a way to re-encode without lossing quality or a increase in size a step by step guide whoud be nice if posseiblefollowing is the video media info
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 49mn
Bit rate mode : Variable
Nominal bit rate : 2 190 Kbps
Maximum bit rate : 20.0 Mbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.860
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.104
Writing library : x264 core 114 r1924 08d04a4
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / slices=4 / nr=100 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=2 / weightp=0 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=2190 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=20000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Not possible without re-encoding
How are you playing this back? What software or hardware has the problems with the seek ? Note some older decoders did not support open gop -
wait; are you saying it seeks fine in mkv container? But only when you re-wrap into mp4 seeking becomes a problem ?
If so, how you are you re-wrapping ? Try something else like yamb, mp4creator, ffmpeg -
Try mkvtomp4
https://forum.videohelp.com/threads/340675-Mkv%D0%A2%D0%BEMp4-v0-218-rapid-tool-for-repack-Mkv-to-Mp4
But it might be a playback configuration problem, like a bad mp4 splitter, try configuring it with lav or haali instead (although vlc doesn't rely on those, it should be ok, but some versions of vlc are buggy)
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 12:19 -
0-GOP in DVDLabPro (DLP)
By grzegorz in forum Authoring (DVD)Replies: 8Last Post: 7th Aug 2010, 01:53 -
MPEG document describing 'open GOP' in detail?
By Alex_ander in forum Video ConversionReplies: 7Last Post: 9th Jun 2008, 13:49 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 12th Feb 2008, 23:14 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 8th Jun 2007, 23:08
