hello
In the changelog for MPC I see the following comment:
- New capture format: dsm, in addition to the already existing avi, ogm (needs external muxer) and matroska formats
I can see how I can convert something to DSM (File > Utils > DSM Converter) but how does one convert to AVI? Is there an "AVI Converter" option just like for DSM? Or do I need some plugin for it?
Also, if I have already converted something to DSM, is there a way to get an AVI out of it? I think I can get the video and audio streams out of the DSM in raw format, but then how do I package them together in an AVI or some other more portable format? Or even convert them to MPEG2 for TiVo?
thank you
PS: not sure whether this thread should go in the conversion forums instead.
Well I would assume it uses the system avi mux filter (that you would use with graphedit). Never captured anything with MPC though. Note we are talking (as per the changelog) about capturing here. According to the code though you would have a drop down list where:
0 = avi
1 = ogm
2 = mkv
3 = dsm
Not sure how ogm would work though since MPC doesn't include a filter and it doesn't come with windows. -
Yes, I was trying to use for capturing and saving an mms stream. I know there are other apps that can do it, but I'm no big fan of installing more and more apps.
Anyway, under File > Utils > DSM Converter > Save As, I see the type dropdown but the only option seems to be DSM. Is it because MPC disabled the other options so that it pushes its own format or am I missing something that I would have to install (avi muxer?)
Btw, for ogm, the changelog says "ogm (needs external muxer)" - which doesn't mean much to me.
Encoding Video for a D-Link DSM-510 MEDIA PLAYER
By loughary in forum Video ConversionReplies: 1Last Post: 9th Oct 2009, 21:37 -
AAC 5.1CH audio plays as 2CH on my DSM-750 media player
By roise_r in forum AudioReplies: 0Last Post: 22nd Aug 2009, 22:45 -
no sound in some avi's with Media Player Classic
By DraWing in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 23:29 -
streaming with media player classic + Mega K-Lite Pack problem for AVI
By set69 in forum Software PlayingReplies: 5Last Post: 11th Feb 2009, 20:02 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49
