Ok, so normally if I convert avi to dvd using merge into one dvd and I burn the files then play it. After finishing the first episode, the second doesnt have any sound. So I dont know whats the problem is but then I choose to use merge into 1 title, and the dvd player read it well (sound and pic working great). So, I use that method to convert a series but now, I try to convert a new series into dvd. It doesnt work anymore, the conversion bar freeze at 17%. When I open what it has converted so far, its like at the end of the episode 1, so it freeze at begining of episode 2. You guys have any idea?
PS: one of the file have different dimension so I change them into the same but they have like different code or something ( one is xvid, one is dvixd or something). Is the code is the problem?
Thanks for helping.
WinAVI is your problem. Either use ConvertXtoDVD, or start reading some of the guides and learn how to do these conversions properly.
Read my blog here.
it works fine before, its like just today, I try to convert another clips and it happens.
Since it's a commercial product, WinAVI ought to offer some support (more than suggesting their customers to go to VideoHelp for support).
/Mats
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 16:28 -
Help needed for video conversion : Winavi
By leoboms in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2010, 13:48 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
WinAVI 8.0 - DVD to AVI - Target Size 700MB?
By ivisitpublix in forum DVD RippingReplies: 2Last Post: 24th Aug 2007, 13:01
