    Oct 2006
    Ok, so normally if I convert avi to dvd using merge into one dvd and I burn the files then play it. After finishing the first episode, the second doesnt have any sound. So I dont know whats the problem is but then I choose to use merge into 1 title, and the dvd player read it well (sound and pic working great). So, I use that method to convert a series but now, I try to convert a new series into dvd. It doesnt work anymore, the conversion bar freeze at 17%. When I open what it has converted so far, its like at the end of the episode 1, so it freeze at begining of episode 2. You guys have any idea?
    PS: one of the file have different dimension so I change them into the same but they have like different code or something ( one is xvid, one is dvixd or something). Is the code is the problem?
    Thanks for helping.
    Apr 2004
    Miskatonic U
    WinAVI is your problem. Either use ConvertXtoDVD, or start reading some of the guides and learn how to do these conversions properly.
    Read my blog here.
    Oct 2006
    it works fine before, its like just today, I try to convert another clips and it happens.
    Apr 2004
    Miskatonic U
    Did oyu upgrade WinAVI recently. Every second point release seems to break the release before it. Honestly, it is a rip off if you paid for it, and more fool you for installing it if you didn't.
    Read my blog here.
    Oct 2006
    I used a newest version which is 7.7 so yea..
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Since it's a commercial product, WinAVI ought to offer some support (more than suggesting their customers to go to VideoHelp for support).
    /Mats
    Oct 2006
    /Mats
    Wow..that helps alot..
