I'm planning to build a website well contain an on demand educational movies , i thinck it don't need high resolution because it has no high detailes some text and my desktop to explaine programs i want to work on ..
Probelm is i don't know how to compress these files , and what streaming software to use >>
Results 1 to 11 of 11
The best quality streaming video I have seen for presenting screenshots and screencam footage has been quicktime, although I don't know how exactly it was encoded. To preserve the screen details you will need a fairly high resolution and a good bitrate, neither of which are conducive to happy streaming.
Read my blog here.
Flash 8 and use the built in Flash video encoder ($700 though...)
700$ for program is too much money for me ..
is there any freeware to do that ? -
wmv is pretty good for streaming media too. Windows Media Encoder is free.
/Mats -
You can use the free Riva FLV Encoder but you also need to include a flash player and make a flash swf. Or use On2 Flix Video ($40), very easy to use and gooood quality and makes flash swf directly.
Or make WMV as mats says with WME or WMM. -
Geeze man! How'd you even find this website without knowing how to even spell "video"?
Darryl -
I too have had good success with the "Flix" products. AFAIK, they're the only ones that do Flash 8 video less expensively, except for the $700 Adobe package mentioned above. From what I've seen, Flash 8 is a lot better quality and now almost as widespread as Flash 7. But all Flash video is cross-platform and hassle-free, which are its biggest advantages IMO.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick -
i'm not from usa or even my mother language is english so, it is not important to spill english words right ,, the important thing is how to use the technology right.. not the wordsOriginally Posted by dphirschler
if u can help with something bigger than grammar plz do -
There is still no Flash 8 plugin for linux and no plugin at all for x86-64. Not exactly cross platform.
For screen capture, etc. you are probably better off doing it directly in flash rather than with video using something like RoboDemo which I think is now Adobe Captivate ($600USD).
how to add watermark in vedio
By ShrinkDWorld in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2011, 20:31 -
How to convert HD MKV Vedio to Avi to play on my LG LED TV???????
By Sh@DY in forum Video ConversionReplies: 27Last Post: 2nd Oct 2010, 06:44 -
how to put subtitles under the vedio !
By ary190ary in forum SubtitleReplies: 4Last Post: 31st May 2010, 17:48 -
i have some mkv vedio and i want to convert it to .divx
By The1One in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2008, 12:07 -
VOB, AVI TO RM problem with audio and vedio sync
By soft in forum DVD RippingReplies: 1Last Post: 8th Aug 2007, 00:16
