    Sep 2007
    I record on DVD-RW. First playback is fine. Later playback attempts results in long
    "LOADING" and then "NO DISC" error. I take same DVD-RW and it plays in my
    $25 DVD player. Thanks.
    Jan 2005
    Most likely a media problem. Double check that your -RW discs are Ver. 1.1 1x-2x.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The easiest check, is to get a few different brands of media (preferably name brand media...try Verbatim) and see if they all show the same problem. If some of them work, then you are having typical media issues...not all media works in all players. If they all have the same problem, then you are having a hardware issue. Time to clean/replace the JVC.
    Google is your Friend
    Use good discs. www.nomorecoasters.com
    2010 update -- Fixing the JVC DVD Recorder "LOADING" Issue / JVC Will Not Recognize Blank DVDs
    I've compiled a new thread on this topic at http://www.digitalfaq.com/forum/showthread.php/fixing-jvc-dvd-2008.html -- I've been trying to organized all available JVC information better for those who need it!
