I have an avi file which when i loaded it in virtualdubmod and went to stream list I found that it had two audio files.Does anyone knows how to save this avi file with one audio file only,pls?
Hello from the island of Malta.
Pick the one you want and select 'Delete' for the other one. (This won't damage the original file.) Then if you want to save it as a new file with just the one track, use 'save as' and 'Direct stream copy' for the audio and video and specify a new filename. Only takes a few minutes.
Simple editing of the video and you can save them the same way. If you filter or resize or make other major changes, you will have to re-encode the video, but you can still use Direct stream for the audio, as long as you don't change it's format.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
Append the same AVI file on 70 different AVI files?
By Speed Demon in forum EditingReplies: 3Last Post: 15th Sep 2007, 04:55 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
