  1. Banned
    Oct 2006
    ok i'm using convertxtodvd to turn my avi files to vob now i've authored with this program once and it does a great job, but i guess this goess for nero too. i would make my dvd's but the size of the vids showing are a bit too wide or stretched out for the subtitle to to. for example i'm watchin lets say Naruto or something like that and the intro will come on and the subtitles will go off scream a bit. so how can i fix this?
    Apr 2004
    Miskatonic U
    First you search, then you find that this has been dealt with a thousand time or more. The issue is overscan. Nothing has been cut off. It is all there. Play the DVD back on the PC and check. Your TV hides the edges of the screen - all TVs do, to some degree. Fan-subbers are stupid when it comes to placement of the subs, and continue to place them so that they disappear into the overscan area. You would think that by now they would understand and get it right, but no, they haven't.
    How to fix ? FitCD and avisynth. FitCD will create an avisynth script that will resize your avi and add borders around the edges so your subs stay on screen on yor TV. If you have the latest version of ConvertXtoDVD then you can load the avisynth script and encode from there. If you don't have the latest version, upgrade or learn to use a proper encoder.
    Read my blog here.
  3. Banned
    Oct 2006
    thanks i'll look into that and try it
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Are the subtitles burnt into the image or a separate file (eg, srt)? If the latter, you can reformat using, eg, Subtitle Workshop. If the subs are in the sup bitmap format, you can use Subrip to OCR them back to text (but you should proofread) and then to reformat as above.
