I am sure there are many, but I need something that is proven, has many features, transitions and can create slide show with 16x9 aspect ratio that can be burned on DVD and played on a regular DVD player. It can be freeware or paid.
Thanks.
Results 1 to 10 of 10
Check out http://www.lqgraphics.com/software/index.php - LQ Graphics Software: Photo to Movie.
Hi...
try this freeware DVD slideshow GUI
the link above didnt work
use this one instead http://download.videohelp.com/tin2tin/
stars... -
Photodex ProShow Producer: http://www.photodex.com/products/eid8641/producer/
See also: www.ViewPixmedia.com -
Also, have a look at MS PhotoStory 3
/Mats -
See this list of how to author a slide show;
https://www.videohelp.com/author#3;52
A short list of them, most already mentioned are;
ProShow Gold
MemoriesonTV
Dvd slide show GUI
Win DVD creator
PhotoStory 3 (note needs $20 Sonic Plug in to burn)
For quick Slide shows I would recommend the Memories onTV because of the capablity of having the show fit the length of music. But doesn't have a sound editor, Note, I am still using ver 2.2 , I believe thats changed with ver 3. I've used Win DVD creator, very tedious but better control, I am not sure about outputting 16:9 format. -
DVD Pixplay will do everything except the Ken Burns effect, and has a pleasing easy to use interface. Still only $29.95.
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 04:40 -
Can anyone recomend audio recording software for background music?
By bweath in forum AudioReplies: 4Last Post: 18th Jun 2010, 06:12 -
Need DVD Slide Show software recommendation FAST!
By lbblock in forum Newbie / General discussionsReplies: 11Last Post: 14th Mar 2010, 15:58 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2010, 00:57 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27
