I can convert movies to my PSP and i can also convert .flv files to my PSP. i think they are MP4 files that are stored on the PSP card. BUT i want to edit either the .flv file or the converted psp file. i have TOTAL VIDEO CONVERTER but if i use the edit function on it to convert a segment of the .flv file, it doesnt work. SO my question is...........is there a .flv file editor or a PSP file editor available to do this![]()
am i correct in thinking that the PSP video files are just MP4 files.
Yes. I believe originally they require some custom atoms, but now (due to an PSP update) they are stock standard mp4's.
can u suggest an easy to use MP4 editor that will just do the basic functions. sorry to be a newbie
dont suppose you know what settings to use do you, its exaclty what im looking for but just cant seem to get it setup right to output a valid PSP video file!
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 22:20 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
How to copy a movie onto Sony PSP?
By coody in forum Portable VideoReplies: 1Last Post: 10th Aug 2008, 09:34 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
.VOB to PSP-Movie issue. Certain won't convert
By egmadayag in forum MacReplies: 5Last Post: 23rd Oct 2007, 15:14
