I'm converting OGG/MKV files onto DVD I use a program by Cucusoft which converts OGG/MKV media but I want it in japanese but you can't select the audio stream you wish it goes with the first one which happens to be english but if I can change the settings for when i open it to be japanese not english then it would work cause I can do that with the subtitles but I can't seem to do it with the language.
Results 1 to 1 of 1
One Shall Stand One Shall Fall - Autobot leader and keeper of the matrix Optimus Prime
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 15:53 -
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 04:59 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
TMPGEnc AW 4: default audio stream for different tracks
By reini in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2009, 14:33 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 19:10
