Hi,
I created a DVD containing several tracks (due to different video-formats of the clips). Each track has 2 different audio-streams. When I'm playing the DVD track by track I want to keep listening to the same audio-stream. That means: I'm choosing audio 2 of track 1 within my DVD-player. After the end of track 1, track 2 starts automatically. The audio-stream should stay nr.2. But right now it switches back to stream 1. Just when I press the "skip forward" button to play the next track, audio 2 stays the active stream.
When I press the menu-button during playback of track 1, then I choose track 2 from the menu, track 2 starts with audio 1 too, even if I was listening to audio 2 just before.
Is it possible to define an "actual" audio stream for multiple tracks with TMPGEnc, like it could be done for just 1 track by the audio-setup page?
It can be done, but I suspect not by using tmpgenc. You would have to get in behind the authoring and add extra code. You might be able to use PGCEdit to make the changes. I would normally author something like this in DVD Lab Pro.
Read my blog here.
If each file is in a seperate track, go to the "settings" button in the track select column on the left of the source tab. It opens up a tabbed window where you can change the rendering settings but it also has under the audio and subtitle settings drop down menus where you can tell it what is the default or automatic audio/subtitle for each track (you can also label the languages).
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 15:53 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Change default tracks in mkv (batch)
By Gabbsmo in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 08:58 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 19:10 -
multiple audio tracks in transport stream
By levide in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 12:58
