is there a program to put audio which is out of sync with video back to normal
not automagically.
what kind of sync problem is it? does it get worse or is it same? -
well the voices are not in line with the video i converted this .avi movie to .vob files and it has 23 chapters and up to chapter 11 all is ok but after that the voices are not right
i would give up then....
is the avi in sync?
what is the audio codec in the avi source file? identify with for example avi2clipboard -
ok i used avi2clipboard here is results
File Name ..........: Back To The Future 3.avi
Total Size (Bytes) .: 869,512,490 Bytes
Total Size (KB) ....: 849,133 KB
Total Size (MB) ....: 829.23 MB
Total Streams ......: 2 Stream(s)
Video Size (Bytes) .: 770,940,406 Bytes
Video Size (KB) ....: 752,871 KB
Video Size (MB) ....: 735.23 MB
Video Length .......: 01:53:23
Video Codec Code ...: XVID/yv12
Video Codec Name ...: XviD MPEG-4 codec
Video Bitrate ......: 906 KB/s
Resolution .........: 416 x 224
Aspect Ratio .......: 1.85:1
Total Frames .......: 170087 Frames
Framerate ..........: 25 FPS
Color Depth ........: 24 Bits
Quality Factor .....: 0.389 B/px
Audio Size (Bytes) .: 98,561,864 Bytes
Audio Size (KB) ....: 96,252 KB
Audio Size (MB) ....: 94.00 MB
Audio Length .......: 01:53:23
Audio Codec Code ...: 85
Audio Codec Name ...: MPEG-1 Layer 3 (MP3)
Audio Bitrate ......: 115 KB/s
Channels ...........: 2 Ch
Sampling Rate ......: 48000 Hz
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
