I used DVDshrink's reauthor mode, to extract the main movie, and out take, and some delete scenes. They ended up in VTS_01_x.vob, and VTS_02_x.vob..... If I burn these into a DVDR, and play it. There will be some pause, between these VOB sets, and some players can't rewind thru these VOB sets too.
I put them in a folder, and removed all their ifo, and bfo, and renamed them from VTS_01_0, to VTS_01_9.VIB. then use ifoedit to create then ifo file.
The final DVD does not plays all the way thru, and stopped.
I don't think I can use TDA, because my version does not handle dolby 5.1 sound tracks.
Any suggestions about how to make a better re-authored DVD ?
Results 1 to 10 of 10
http://members.dodo.net.au/~jimmalenko/test.htm might help.
You can actually use any version of TDA with 5.1 DD sound - it should just allow it to "pass through" if you don't do any editing.If in doubt, Google it. -
This guide may help:
http://forum.digital-digest.com/showthread.php?t=60724 -
Thank you. I checked and find out I did not change to 001,002...
Specialy about the steps to use VOB extra to fix the packing erro. though there is another program that can do this too ? -
You can try the free DVDSubEdit
https://www.videohelp.com/~DVDSubEdit/ -
Er, one more. The English subtitle is always on, on PC and player. I have to force all subtitle to : normal start. I also need to go into ifoedit to set subtitle and audio language and present.
Is there another way to join the clips and preserve the subtitle and audio track propertes ?
Join and Convert VOB FIles
By solai_4 in forum Video ConversionReplies: 3Last Post: 18th Mar 2010, 04:27 -
authoring dvd using a group of vob files
By sumeshkri in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2008, 10:23 -
how do i join VOB files
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 4th Oct 2007, 08:10 -
How to join 2 DVD VOB files??
By hilario in forum EditingReplies: 5Last Post: 15th May 2007, 17:53
