Results 1 to 13 of 13
    Apr 2006
    I am comparing picture taken from the movie schindlers list (DVD-retail)
    The comparing regards nero 7 recode downsized to 70% VS the original quality
    the picture is taken from an original dvd ends with a "1"
    the rest that ends with a "0" is trancoded with nero recode (nero 7) with highest quality....down to 70%
    for exampel 10 is the recoded picture
    and the 11 is a original picture...
    nr 40,41 and 50,51 and 60,61 are high zoomed pictures....download them....
    on these pictures you can actually see a worse quality with recode..but so small
    you can actually see the size of the files that the original are a few kb bigger then the recoded..
    so there you have the answer of dvd-shrink and nero recode.....so high quality...and takes only about 90 minuts.....if you use CCE with dvd-rebuild...takes many many hours...
    had to make this test just find out for myselves...so many says that CCE is so much better compare to dvd-shrink and nero rebuild........the good thing with nero and dvd-shrink is that you can take away all the crap like menu and so on...just have the movie...also you can keep the extras at the end of the movie..
    why do you want to keep the menu ?.......just take the movie and the extra...easy with dvd-shrink
    please write what you think...what do you think?
    download my picture and use "windows picture and fax viewer" (in the start menu) and press page up and down to compare the picutres....they are already sorted (thats why i have the name of the file 10 11 etc.)
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
    Apr 2006
