Heres a link to the card
http://www.pcworld.co.uk/martprd/store/pcw_page.jsp?BV_SessionID=@@@@1813499037.114466...ned&tabIndex=1
the tv i have currently got lets me watch tv aswell as use it as my monitor, so i dont need it to watch tv.I need it to record the tv, would this beable to do it?
Results 1 to 16 of 16
Apart from image quality, less effort may be required to capture if you can grab the transport streams from the broadcast, instead of having to encode them yourself on the fly. If you can afford a high def card, the image quality will be much better than you can get from an analogue card.
Read my blog here.
ok, which card would u reccomend from this list
http://www.pcworld.co.uk/martprd/store/pcw_page.jsp?BV_SessionID=@@@@1046832819.114466...&show_all=true -
MODS CAN U MOVE THIS THREAD TO THE DIGITAL TV SECTION PLZ, I WAS TOLD TO ASK THX
thx
so anyone got any suggestions?
i was looking at the second one on the list, would this give good quality? -
i think this one looks good
http://www.pcworld.co.uk/martprd/store/pcw_page.jsp?BV_SessionID=@@@@1792745759.114468...8&tm=undefined
would this beable to record from another tv or a ps2? -
Originally Posted by peter762033
You should check out the capture card section of this site.
yes that will record TV but isn't very reliable(audio sync problems).And at 70 quid or $140 is way overpriced for an old card like the 150.(at lest a5 yr old card?)
At the risk of being shot I would check out the ati all in wonder. -
the ati all in wonder is way out of my price range, i was thinking more like 20-70
If you are tuning to an analog broadcast, I recommend a tuner card with hardware encoding like the Hauppauge PVR series. These will encode the analog broadcast to MPeg2 in hardware and won't load the computer.
If you are tuning a digital TV broadcast, it is best to capture the digital stream directly with a DTV/HDTV capture card for best quality.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Reconsider your budget if necessary to get hardware encoding. You won't like the performance of a non-encoding card and will end up buying another anyway.Originally Posted by peter762033
im not sure wether im watching analogue or digital?Could u reccomend one from the list, theres a link a little further up the page
Record to memory card via firewire port?
By poflynn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 3rd Aug 2011, 15:18 -
which TV tuner card can record closed caption?
By Louis76013 in forum Newbie / General discussionsReplies: 6Last Post: 17th Apr 2010, 10:23 -
How can I record without TV card?
By Xavier in forum DVB / IPTVReplies: 4Last Post: 17th Apr 2008, 06:58 -
The best card to watch/record HDTV?
By Chuck_Johnson in forum DVB / IPTVReplies: 31Last Post: 9th Feb 2008, 11:05 -
question about tuner card to record TV
By jimdagys in forum Capturing and VCRReplies: 11Last Post: 22nd Nov 2007, 06:17
