The file below are the options that my capture program let me. What is the difference? Is the next step should be encoding to MPEG 2 and then authoring a DVD?
DVD-Pal
PAL (25 fps)
Field order A
MPEG files
24 Bits, 720 x 576, 25 fps
(MPEG-1)
Video data rate: 2000 kbps
Audio data rate: 128 kbps
Layer 2, 44 kHz, Joint stereo
AVI DV- Pal
PAL (25 fps)
Frame-based
Microsoft AVI files
DV Video Encoder -- type 1
DV Audio -- PAL, 48.000 kHz, 16 Bit, Stereo
The top one is MPEG-1, which could be used for a DVD without encoding, as it is already DVD compliant resolution, but would be low quality at that bitrate. The audio would also have to be converted to use on a DVD, it needs to be 48K. This appears to be a odd format.
It would be much more practical at 1/2 D1 resolution of 352 X 576, 48k audio, as the low bitrate would work better. Or you could use MPEG-1 VCD format that would be at a fixed bitrate of 1150kbps, 44K audio, 352 X 288 resolution. VCD would work for a DVD, but the audio would have to be converted to 48K.
The bottom is AVI-DV video, which is higher quality, but would have to be encoded. DV video is much easier to edit than the MPEG-1. It can also be encoded to MPEG-2, a higher quality version of MPEG for a DVD. Type 2 DV is usually more compatible with encoders like TMPGEnc.
What capture program (or capture device) are you referring to? -
somehow I cannot use the top one, hoever I have found a different type of file:
PAL DV Avi
PAL (25 fps)
Field order A
Microsoft AVI files
The only diffirence is that this one is file order A and the other one is frame based. What is the difference?
I plan to encode to MPEG-2 and then to author a DVD.
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 16:44 -
What's the difference between _TS and .ts files?
By Yellow Peril in forum Video ConversionReplies: 3Last Post: 1st Apr 2011, 05:16 -
is it possible to feel the difference?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 06:17 -
What is the difference between these Taiyo's?
By ha13may in forum MediaReplies: 3Last Post: 27th Sep 2008, 15:01 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
