Hi all,
Which is the better one to use for the best quality CBR or VBR, as my footage is 1hr long and i have another footage for 2hrs long?
Cheers Josel
Hi josel,
Read up on what CBR and VBR are, and how they work - you'll see it's a bit like asking "What's better: an apple or an orange?"
The quick answer is to use CBR whenever you can, and use VBR only when you need to.
As to whether to use CBR or VBR, this link will help:
http://dvd-hq.info/Calculator.html#CalculatorThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 14:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 18:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
VBR, ABR and CBR ??
By moiz in forum AudioReplies: 11Last Post: 19th Oct 2008, 17:22 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 14:28
